Results 1 to 11 of 11
Thread: 250r rpm runaway
    PAPA250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    greentown PA
    389
    250r rpm runaway
    I have a ported and piped 250r . sometimes I have a strange problem. if I'm getting low on gas and forget to hit reserve. the engine rpms will run away in neutral after the ride.
    I mean REALLY run away almost to the point I feel a pitson is going to go through my leg..lol
    holding the kill button has no effect and choking it does nothing even makes it a little worse .
    what gives ? when I put it on reserve it calms down once it gets gas again .
    this only hapens on the rare occasion I run the gas down too low.
    I'm runnin 32:1
    thanks for any insight !
    84 200s almost done
    84 atc 70 project
    Jun 2009
    Tunkhannock,Pa
    904
    its because its runs very lean when you run out of gas in a 2 stroke
    1985 200X
    66mm H&S Piston
    Little Bit Bigger Cam
    Bassani Exhaust
    1985 350X With Bassani Exhaust
    1983 Honda 200E (PARTING OUT!!!!)
    1985 Yamaha Tri-Zinger
    My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
    Baltimore, MD
    6,088
    The infamous leaned out death rev!
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Billy Golightly's Avatar
    Live Oak, FL
    15,068
    The above posters are correct, to break it down a little further:
    A higher air mixture going into the fuel, is more volatile, causing the engine to rev higher. When the tank is running out of fuel, your getting air into the system, and not a continous stream of liquid fuel. This "leans" out the fuel mixture and makes the engine rev more. This is a very bad thing. After a certain point, the engine gets hot enough that it "pre-detonates" which means that a certain point in the motor (on the inside of the combustion chamber, probably on the underside of the head) is getting so hot, that, that point is igniting the fuel mixture before and WITHOUT the spark ignition of the spark plug. Technically its similar to a diesel motor, and it might be referred to as "dieseling" by some people. So then the engine is "firing" faster, and its getting a higher potency fuel that makes it continue to climb RPMS until it either flings itself apart (Remember, the spark ignition isn't running it, so turning it off does nothing, AND its not RPM limited by ignition timing advance/retard abilities anymore either!) or it just runs out of gas. The best thing to do is at the first hint of it running out of gas, turn the reserve on.
    Feb 2009
    greentown PA
    389
    I don't like the sounds of 'death rev' lol
    I'm going to make an effert to keep it toped off at all times so this never happens again . .
    could this happen while riding ? it would sure be a wiked ride more like a missle
    thanks for the replys
    84 200s almost done
    84 atc 70 project
    Baltimore, MD
    6,088
    Usually if it happens while riding, uncool things happen.
    Nicholson 185s
    Jackson MI
    1,688
    This will sound Wrong, but If you hold the throttle wide open It will shut off almost Instantly (pull the clutch In of course If your riding It LOL). The sudden burst of air will kill the engine right Now, and will Quickly cool the cylinder.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    mrtwidster1 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2007
    tn. usa
    169
    Ah Yes!!
    The old DEATH REV!!
    Had it happen on my first 84 R. Scared me real bad!! Toasted my top end!!
    My Son had it happen on his 84 also, Same result. Scared real bad and toasted top end!
    Thanks for the explanation Billy! That was one of the best I have seen so far.
    Mr Hall that is a great tip! Just hope I never have to use it.!
    Apr 2010
    KC, MO
    64
    or you could have an airleak mine did the same stuff when i had the base basket goin bad
    Sep 2009
    Washington
    553
    One of the reasons I never leave camp without a full tank.... Never.
    2) 1977 Honda ATC90
    2)1985 Tecate
    2005 Banshee LE
    01 Honda 300EX
    74 Suzuki TC100
    66 Honda 305 Scrambler
    Sep 2007
    100mi west of Chicago
    3,582
    I tried to tell my brother not to run the gas out of the carb before putting away his CR125R because of this. He would turn off the gas from the tank and ride the bike around till it died. I thought he understood that on a 2-smoke it if isn't getting gas then it's not getting lubricated either but maybe he didn't. In the short time he had the bike he did get lucky and not have it happen though
    Rob
