Results 1 to 15 of 20
Thread: Witch motor should I put in my 85 atc 200x?
    Visalia, CA
    720
    I have two choices......A crf450 motor with a 488 kit in it.OR a 200x motor bored and stroked out to 252cc's with a 6 speed tranny and a CRAP LOAD of other mods. So witch motor would you choose?
    Hawaii
    84
    Your Joking right? Eh!!!? What ever!
    Worcester, MA
    1,117
    Would the CRF engine even come remotely close to fitting in the frame? Is the sprocket on the same side?
    ct
    1,396
    ummmm the 200X motor because the crf450 will never ever ever ever fit
    Visalia, CA
    720
    Yes the crf motors Have the sprocket on the shifter side.Same as the 200x. And I have many many drawings of how I'm gonna fit the motor in the frame. So I'm kinda leaning to the crf450 motor.
    Jul 2006
    western ny
    3,366
    id go with the 200x .. less mods and if its got the mods u say it does thats all your gunna need in a 200x
    GIT IT RAAAGGGGG !!!!
    ct
    1,396
    gotta see where you are going to put the radiators and the airbox.Honda engineers had a hell of a time fitting it into the crf450R mx bike.
    if you somehow made it work, the suspension alone would be horribly unbalanced and the power would be stupid. Why not start with a crf frame and go from there????
    Visalia, CA
    720
    Quote Originally Posted by whyzee View Post
    This cracks me up.
    Sep 2007
    100mi west of Chicago
    3,582
    What year is the 200x engine? If it is 83-85 it must have an XR200 tranny?
    Rob
    Visalia, CA
    720
    The big bore/stroker 200x motor has a xr200 bottom end. Its a 1985 200x.
    Visalia, CA
    720
    I know what set up your talking about its just to pricy
    Williamstown PA
    5,825
    build up a 200x motor right, with all XR stuff, powrol 218 kit...it will run good. 450R motor wont fit, 200x has a tiny frame.
    Visalia, CA
    720
    Its not that tiny if you stretch the frame a bit and cut and expand the mid part of it to.
    Williamstown PA
    5,825
    where ya gonna fab radiators, a 200x is really not the best idea to cut up the frames. you gotta make them taller anyway to clear everything.
    Visalia, CA
    720
    I would use a 1985 tecate 3 radiator and mount it on the forks. Also to hide it I would find a vented number plate. I also know what kind of work this is going to require.
