Results 1 to 3 of 3
Thread: 200s spark issue
    Pittsburgh
    22
    200s spark issue
    I recently picked up a junker 200s with no spark. I took the coil and the cdi box off of my other trike to no avail, I found a good used stator and got it to run for a second on ether, then it quit sparking.
    The pulse generator looked like crap (wouldn't move and a spring was broken) so it was changed also.
    What are the odds the other stator is bad? and is there a way to check them? thanks in advance
    JustEnough's Avatar
    JustEnough is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2009
    Elk Grove, CA
    334
    I got a 84 200M to go from one weak spark at the beginning of the pull to a fat spark every revolution. The solution was to wire brush the connections at the primary coil and at the bullet connectors for the wires. I think it was not getting a good ground.
    Nov 2009
    N Hollywood/ CA
    588
    Good idea justenough & also check forloose wires. Sometime the ground is the key factor in these issues.
