Results 1 to 10 of 10
Thread: Something is seriously wrong with my trike
    Apr 2010
    Canada
    17
    Unhappy Something is seriously wrong with my trike
    Hey,
    Earlier today I checked the oil in my 86 Yamaha Tri-moto 225 and noticed that the oil was a bit low.
    Now, I managed to find some 10w30 so I put a full bottle in. Please note that I have never done this before.
    I then went riding around my property on and off through the day. Well about 30mins ago I took my trike for the first time for about a 5-15min ride down a dirt road. The throttle was pinned the whole time.
    When I stopped for about 10mins, the person that was with me, pointed out that the trike was leaking alot of oil out of the air box.
    This has never happened before and now I am nerves on what I should do.
    Does anyone know what happened and what the issue is?
    Thanks guys
    Masshole
    2,191
    ya, its coming out the breather into the airbox because you put too much in. Check the oil level.
    Nov 2009
    N Hollywood/ CA
    588
    an 86 tri-moto, oh jiz, please check the level before dumping the whole bottle kid cash! I'm in tears..
    haggard 2hundie's Avatar
    haggard 2hundie is offline Would rather be at the front of the train than Arm chair racerJust too addicted
    muscatine, iowa
    764
    not sure about the yamahas but on my honda 200x you check the oil level on the dipstick without screwing the dipstick in just a thought
    Southern MN
    1,875
    I agree with jeff up there^ You put too much oil in it. Drain the oil out, and put fresh in. Check it after one qt. , But I believe it takes about 2 if its completly empty. Dont quote me on that. Check it as you fill. It also wouldnt be a bad idea to change the oil filter, its a paper element, and should be changed at least a few times a year. Any dealer should be able to help you out, or a shop. While your at it, also check/change the rear differential fluid. Find a manual if needed. Good luck!
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Kokomo indiana
    80
    it takes 1.5 to fill, 1.8 quarts if you change filter. so drain the oil , change the filter then put 1.5 quarts in, check the dip stick, then add small amount till full but shouldnt be more than 1.8. So if it was a bit low and stii showed on the dipstick, you probably put about .8 quarts to much
    Kokomo indiana
    80
    Quote Originally Posted by haggard 2hundie View Post
    correct, just rest the dipstick on the threads dont screw it in
    1,736
    seriously? why did you assume it needed a whole bottle when u checked and found it low. if you know to check to see if its low I assume you can check to see if its to much too when your adding oil. see a manual for the proper way to check your oil.....
    Texas 200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Corpus Christi, Tx
    296
    So you don't know what oil was in it before and added a whole bottle of 10w-30? You need to get a copy of the owners manual and read it or there's a good chance your gonna ruin that thing by not knowing what your doing.
    Hey, What other dangerously fun vehicles can I Cram in my 2and1/2-car shop? (Garage.)
    Winnipeg Mb
    113
    Something is not seriously wrong. You put in way to much oil! I agree with Texas 200x
    1988 Honda TRX250R
    fmf pipe, ct national port airbox lid removed worcs front shocks renthal bars maxxis razr's
    1985 Honda Big Red 250ES
    1984 Honda Big Red 200ES
    1982 Yamaha Tri Moto 175
    Please Check Out My Youtube Channel
    http://www.youtube.com/watch?v=Mbwd1...feature=relmfu
