Thread: Will a Yamaha Tri Mo YT175 head/piston/cylinder bolt on a YT125 with no modification?
    Apr 2010
    Sterling Hts, MI.
    10
    I have a 125 that runs good, but it needs the top end refreshed.
    I may convert it to a 175.
    Is it a simple swap, or is there machine work needed?
    Any info/tuning advise would help.
    Thank you
    Maryland
    3,077
    You need the 175 pipe to use the 175 topend but otherwise it will swap the cylinder, head, and piston, no problem.
    Baltimore, MD
    6,088
    The yt175 uses a larger fuel tank. The yt175 uses a vaccuum operated fuel pump. You may want to pick those up as well.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Apr 2010
    Sterling Hts, MI.
    10
    Thank you for all the info!
