Results 1 to 11 of 11
Thread: Metal Head Gaskets??
    Jun 2009
    Tunkhannock,Pa
    904
    I was wondering are OEM metal head gaskets better than aftermarket head gaskets?
    1985 200X
    66mm H&S Piston
    Little Bit Bigger Cam
    Bassani Exhaust
    1985 350X With Bassani Exhaust
    1983 Honda 200E (PARTING OUT!!!!)
    1985 Yamaha Tri-Zinger
    My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
    Visalia, CA
    720
    Yea they are better. At least to me they are..lol
    Jun 2009
    Tunkhannock,Pa
    904
    What would be the advantages?
    1985 200X
    66mm H&S Piston
    Bassani Exhaust
    Apr 2008
    NW, IND.
    842
    Some(thicker) copper gaskets can be annealed and reused.
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    1,736
    metalhead gaskets enjoy good music, aftermarkets do not. LOL
    Nov 2009
    1,147
    Never used a metal one myself but according to a guy I know who built drag engines, in a stock application the paper ones seal better. Super high performance copper is better.
    6,818
    I herd honda changed over to the metal ones because the led content in the original style . I believe the old style is best for stock application . If you can find a copper BAPP one thats the best way to go and you'll never have to buy one again as its reusable .
    Jun 2009
    Tunkhannock,Pa
    904
    Interesting thanks for the info guys.
    1985 200X
    66mm H&S Piston
    Bassani Exhaust
    The OEM gasket is not just a pure copper gasket. I prefer OEM for headgaskets just to be safe. Cardboard is cardboard so I'll use any brand on case covers but many times I use OEM headgaskets but it also depends on the brand and type of motor. Some are notorious for failures if anything other than OEM is used.
    Admittedly, I have had no issues with any of the Vesrah gasket kits.....
    On the 83/85 200X just make sure to put the o-ring on the right stud or the oil won't get up to the head. Shows you which one in the book.
    Sep 2007
    100mi west of Chicago
    3,582
    I just tore down my 85 Big Red last night and it has a metal headgasket. Is this factory?
    Rob
    Williamstown PA
    5,825
    metal shoul dbe factory. i had a cardboard on on me xr200 and the head leaked badly.
