Originally Posted by
oldtoys72
thanks rob, do you know did the 85's sit lower in the rear? I feel like its just so dang low..... I just went and looked at it again, the "nut" or whatever you want to call it that holds the coild in place is about in the middle of the threads.... is it possible to get more height if i spin it up or down ?
That will add more pre-load to the spring and may help you out some. Hw much do you weigh? has the shock ever been rebuilt? could be low on oil and or nitrogen. It may just be tired but the 83-85 200X isn't know for great suspension action anyhow. The 86/87 200X is better as well as the 350X but the 250R has very good linkage type suspension.
Allot of these older machines sag a bit in the rear but it does look like you have it right. Put some penetrating oil on the pre-load nuts and lift the rear end off the ground. That will make it easier to adjust them....
