im in the market for new rims and I plan on running 22x11x10 tires on them. I guess what I want to know is, is there any advantage/disadvantage to using a 10x10 rim vs. a 10x8 rim?? other than weight, of course. thanks----Joe 8)
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
85 atc350x ('05 christmas present to myself)
84 tecate (my baby)
84 honda 110 (lil buddy)
81 honda 70 (daughters ride)
86 lt250r (sold for parts) R.I.P.
Depends if you want to run a 8" wide tire, or a 10" wide tire.
ATCnut
82 185s - sold
83 200x (hopped up)
84 200x (stock)
84 70 (lost this one to the DMV)
85 70 (soon to have lights, a foot brake, and CDI ignition)
84 200es (parts trike) - sold
85 350X (the best)
85 350X (siezed motor, dream of a poweroll kit someday)
85 250sx (frame was trash, got parted out)
86 250sx (the tractor)
86 250sx (a nicer tractor)
86 250sx (an even nicer tractor)
87 200x (parts trike, its really rough, a dog was chewing on it for a while)
87 250es Big Red (the tank!!)
10" rims are for the track. The advantage is lack of sidewall to flex, and less weight. For trails, some sidewall flex is desireable, but the biggest disadvantage is there is too much rim an not enough tire to protect it. If its rocky where you ride, your 10" rims wont last very long.
Oops, reread your post, and I take it your talking width. Id go with 8" width rim on an 11" wide tire, as thats about typical as the the bead width. If you stretch the bead out to 10" it will lower the profile of your tire even more, which is something you dont need on 10" high rims.
Hey Joe,
even though the KXTs all came stock with 10 in rear rims, I'd go with 8". One thing to remember, If your Tecate is an 85, you will have to switch to the smaller 84 Tecate hubs to run 8" Tires. From your avatar it looks like they are the smaller hubs already. If they are, just order the rims for an 84 KXT hub. Personally, I'd run a 20x8 tire. 22x8 are aweful "baloony".
Nevermind, your talking width. I made the same mistake as TimSr.! on width, I'd stick with the 10" wide rims.
1986 Tecate
1984 Tecate
1985 Tri-Z
1986 ATC350X
1985 ATC250R (2)
1985 ATC125M (2)
1982 ATC70 - Original Owner
175 TriMoto Frame with Pro-Tec Rear Suspension
3-Wheelin' since '82
