I have a big dent to remove from my 73 ATC 70 gas tank.It is from the fork hitting it.What is the best method for removing.Was thinking of heating it and apply air.
If you plan on painting it a body shop could use a stud gun to pull it out, I don't know what you would use to seal the gas cap hole tight enough to hold the air pressure that would require, by the way is there a good way to patch holes in a tank?
dry ice in a towel if the dent is not creased or too big but be careful you ca burn the paint if you hold it on there too long
" Remember .... Women leave, money burns, friends, memories and scars are the only things that truly last forever... and yes that is one of the original General Lees from the series "
Take it to a Paintless Dent Removal guy... might charge you 10-20 bucks...
This is a good sized dent from the fork hitting it.
I also have a dent in my big red tank. When it was a farm machine, a cow got mad one day and kicked the trike right over my uncle
1988 Honda TRX250R
fmf pipe, ct national port airbox lid removed worcs front shocks renthal bars maxxis razr's
1985 Honda Big Red 250ES
1984 Honda Big Red 200ES
1982 Yamaha Tri Moto 175
Please Check Out My Youtube Channel
http://www.youtube.com/watch?v=Mbwd1...feature=relmfu
