Results 1 to 7 of 7
Thread: help installing new maier fenders. Support Wire Thing?
    Feb 2005
    Canada
    663
    Question help installing new maier fenders. Support Wire Thing?
    I put on my fenders but there is some extra hardware for a support wire. I see where to put the bracket on the fender but what is it supposed to connect to or support? Anyone have any idea?
    1984 Honda 250R
    1985 ATC 250SX
    1985 Tri-Z 250
    1983 Honda 250R
    1986 Honda 350X
    1983 Yamaha Tri-Moto 175
    1983 Honda Big Red 200
    1981 Honda ATC 110
    May 2009
    Virginia
    57
    I ran into the same problem when I bought my fenders from Maier. I trashed the wire thing and made my own. On the front mount the brace had a hole on either side and was about an inch away from the fender. I bent the brace so it would match the contour of the fender. Then I got some pieces of 1 inch rubber and put between the fender and bracket. Went to the hardware store and bought 2 chrome pan head bolts. I drilled down thru the fender and bolted it together using lock nuts so it would stay tight and not mess up the fender. It holds really nice and looks good too.
    haggard 2hundie's Avatar
    haggard 2hundie is offline Would rather be at the front of the train than Arm chair racerJust too addicted
    muscatine, iowa
    764
    i didnt even have one on my 200x when i bought it and didnt know it was even supposed to b there till i got a service manual ! maybe thats why my pipe melts the fender hahaha where can i find all the hardware to attach the seat to fender ?i have a new one coming and want to do it right , currently all i have is the 4 bolts that attach the seat latch and 2 bolts near the front of the seat.
    Feb 2005
    Canada
    663
    but what is the bracket supposed to attach to? the frame? Gas tank bracket? my other r does not have anything like this on the fenders. Whats it even supposed to do?
    1984 Honda 250R
    1985 ATC 250SX
    1985 Tri-Z 250
    1983 Honda 250R
    1986 Honda 350X
    1981 Honda ATC 110
    muscatine, iowa
    764
    try and get a service manual , they are a little more informative than the owners manual there should be a diagram in there good luck
    Apr 2003
    Central New York
    1,862
    Maier Rear Fender Support Pics and Instructions
    the lower fender support mounts to the frame and then you use the L brackets and hardware where you drill a hole in each side of fender to mount solid. Have to drill a hole where each L bracket and wire end lines up then use the hardware to attach fender to bracket. I have an original with instructions. I will try to post a pic.
    Attached Thumbnails Attached Thumbnails Maier 86 200X Fender Support instructions.jpg   Maier rear fender support kit.jpg
    84-85 Custom Tecate
    1986 Honda 200X Daily Rider
    2006 Suzuki King Quad
    camy is offline First Time Rider Arm chair racerNew to the board
    Sep 2008
    Quebec, Canada
    84
    good to know! now im missing the steel rod on my bike
    Tomy ATC- my very first trike
    1985 ATC 250SX
    1984 ATC 200X
    1985 ATC 200X - Bought from Yamada. Resto mod 230cc project
    1985 ATC 70 - Full resto... girlfriend's bike
    1984 ATC 70 - In restoration Lifan 120cc in project
    1983 ATC 70 - Full OEM yard beater!!!!
    1973 ATC 70 - resto project
    1986 ATC 250R 330 CT RACING
    3 TRI-ZINGER
    2 ALT50
    3 yamaha 200
