Results 1 to 3 of 3
Thread: new exhaust
    Apr 2010
    Scurry Texas
    4
    new exhaust
    Just got my new cobra exhaust put on my 84 200es big red. Yall guys are right pretty loud. Seems to run alot better still need to rebuild carb. One other question i have is that when you get into high range in the taller gears, when you shift it almost seems like the clutch is slipping. when you shift it will kinda bog just a second before it grabs and goes, all this is done at high speeds. thanks
    Southern MN
    1,875
    It sounds like the clutch plates slipping to me. Have you tried the adjustment screw for the clutch? If that dosnt help, which it probly wont, its time for new fiber/steel friction plates. Not a hard fix, just follow the manual. Good luck!
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Jul 2006
    western ny
    3,366
    my 200s engine did that too .. i replaced the clutch pack and it corrected it .. but try adjusting them first sometimes its all it needs ..
    GIT IT RAAAGGGGG !!!!
