Thread: does this look like a 1979 atc 110 coil
    chula vista
    72
    ok i still havent got a spark on my 79 110 i was wondering if i ned a condenser on this coil or if that litle thing on it its the condenser there only 1 back wire comming out from the coil , well i want to find out if i should attach a condenser i have from a atc90 coil since the coil and the condenser are separete, or if this is how a atc110 coil looks? also since i have a bandito aftermarket frame my coil doesnt fit right i have it attached like this i put some pics up thanks for your help
    Attached Thumbnails Attached Thumbnails atc110.jpg   IMG00376-20100511-1637.jpg   atc110 coil.jpg
    "Never look down on someone, unless your helping them get back up"
    Sep 2009
    Ireland
    89
    Looks the same as mine.
    chula vista
    72
    so i these coils already have the condenser built in because my atc90 coil had the condenser seperate
    Springfield Mo
    3,309
    If the coil is not working you can buy the condenser seprate and just hook it to the condenser connected to the coil. I have done that on several occasions. Some shop will "Bench Test" a coil for you to see if it is good.
    Aug 2010
    mount forest
    3
    does any one know how to hook up a emgo coil to a 79 110
