Ok, so as some of you know, I got a 200X about a month ago now.I haven't had a lot of time to mess with it but recentlly I have. When I got it the guy said it needed a timing chain, well on saturday I was finally able to change the chain. I put it all back together and found no compression waiting for me! Tore the motor down, replaced a couple of seals slapped it back together and there is good compresion now! So I timed it according to the manual using the "T" mark then setting the cam so the holes are at 12 and 6, then rotated flywheel so that it was on the "F" mark like the book says. According to everything it should be "in-time" now but the damn thing will not start or even give me a fire! Its got spark, everything should be right, I cannot figure this thing out! What I'm questioning is that its 180 off. I read that the lobes on the came should point down toward the block, but I also read that the tit on the cam shaft that holds the CDI deal is suppose to be at 4 o'clock instead of ten, that's not possible or the lobes would be skyward. Anyways, it took everything I had at 2:30 this morning when I finally had it all back together bolted into the frame, carb cleaned, everything bolted up and the damn thing wouldn't start again, not to grab the sledge and start hitting! Can you guys plase help me out here, if I don't figure this out soon its goin to ̃he scrap yard and I will start over with something else! I love trikes but this one is cursed I think!
