Well, a couple weeks ago an ad on craigslist motorcycle section caught my eye: a Yamaha Tri-Moto 175, runs, needs carb adjustment, $150. So I check it out: tires are decent and hold air, plastics are faded and a little scratched, but are otherwise ok, seatcover is shredded and faded, but foam is still usable, missing parts of the fender/seat latch, oil tank/pump cable missing, oil hoses blocked off, oil pump cover had a corner of it broken off, carburetor mostly all there, air box off, but is there, missing exhaust endpiece. Frame and forks seemed straight, and best of all, it ran, although quite badly. Offered the seller $100, he sells it to me for $125. I give him a $100 bill and a $25 check.
I transport it home, take the carb apart and clean it thoroughly, get it running, but have a hard time tuning it to run right. doesn't want to idle very low, and tends to bog and die at mid-high RPM's. Little to no smoke coming out exhaust (uh-oh, not good). So after about ten minutes I shut her down.
It sits for about a week or so. Weather turns cold again. I decide to drain the old gas and fill it with fresh 40-1 fuel mix. Thing will not start for nothing. Odd, it had previously started real easy, sometimes needed a little priming of fuel through the carb, but would always fire right up. This time nothing, except the occasional pop. Great spark (even changed plugs at one point), compression seemed decent (enough to blow my finger off the hole), and was definitely getting fuel. I even tried removing the carb and spraying fuel directly into the reeds. Nada. So know I'm getting worried. I pull the exhaust, have a look at the piston. Crap.Significant scoring on the rings and piston. So I figure that running it lean musta effed it up. Start pricing piston kits on ebay.
So I have this pretty cool old nitro RC heli that I traded (along with a Traxxas Stampede monster truck) for an old '84 Yamaha VMax snowmobile with a busted track that I needed to get rid of. I decide to trade a guy the heli for a Tri-Moto 175 parts trike with a good motor but a bent frame. What the hell, I figured I'd have a hard time getting $200 for the 'copter (I decided I'd rather sell it than crash it), and that I'd likely spend well over $200 for a top end rebuild.
Right before I leave to go check the parts trike out, just for crap and giggles I decide to try starting the original motor one more time. With the carb off I shoot a little mix into the reed cage and give 'er a pull. Whadda you know, the damn thing starts right upBut based on what I saw when I looked at the rings and piston thru the exhaust port, I decided to check out the parts trike anyway.
Pulling the motors turned out to be more time consuming than I thought, and I discovered the donor motor had a pretty good oil leak. The shifter shaft seal was really loose, and I hoped that was the culprit. So I ordered the part, replaced the seal, cleaned the motor and the trike up as best I could (amazing how rock hard the dirt on the frame becomes after years of use and never being properly cleaned).
I got her back together and used the parts bike plastics, fender mount, seat (homemade recover job, kinda amateurish, but still better than the original seat by far), and exhaust. I also decided to use the oil injection system that came with the donor bike and drained the old oil from the tank and mounted it to it's new frame. Before starting the motor for the first time in it's new home, I decided to change the transmission oil. I was pretty bummed when a large amount of gray, watery oil came gushing out.Apparently, a lot of water got in the tranny. I thought I'd been careful not to spray any water down the carb and exhaust port when I washed it. IDK...maybe it was already there before I washed it. Only thing I could do was to try to get all of the water out, so I replaced the drain bolt, added about 2/3 of a quart, and pulled the starter cord a few times. Then I drained the fluid until clean oil came out, replaced with clean 30 weight motor oil.
Time to fire her up. To my pleasant surprise, it started the very first pull and ran pretty good.
Took her for the maiden run, and that's when the trouble began. First, it tended to die when I shifted into gear while stationary. I tried lowering the idle, but still no dice. Hopefully, just needs a clutch adjustment. But I was able to keep it running in gear if I gave it a little throttle and allowed it to move while shifting into 1st. I quickly realized something was seriously screwed up when I had to lean hard to the left to go straight, and that it was seriously hard to make a left turn on it. That's when I realized I probably had a bent frame.
There's more to this saga, but I gotta quit writing and go to bed right now. Probably lost most of ya anyway with this long post, but if you're still interested, Ill try to add more to it (pics included) tomorrow. I'll end this tonight by saying there's more problems with this 'ol beater than a bent frame and maladjusted clutch. But I'm determined to fix this 'ol relic just the same.
