Thread: Can anyone help me on a light set-up for 1970 honda atc US90?
    Nov 2009
    N Hollywood/ CA
    588
    Hey guys,
    Can anyone help me out on this, does my 90 come with standard wiring for a direct headlight assembly? Or is it suppose to have an on/off switch like the 200s or 110's? My bike only come with the on/off ignition cut-off switch. or is my bike the model's were the light is automatically turned on when the ignition is on? Another thing, the front forks don't even have the little triangle ears where the round headlight would be bolted on too. Is this particular model a 6V?
    Thx!
    Beaver Falls, PA
    2,666
    A pic of your front end would help
    Lancaster, PA
    1,738
    the us90s used a clamp on headlght braket, (which are hard to find) but Dr ATV has a set of non oem that will work, then all you need is a headlight off a 90 or Dr ATv has a square one that ain't to bad. Next is wiring, should be able to work something out, the orginal headlights used a swith on the headlight that turned it on and off. Check this thread (its about 70s) but the 70s used a us 90 headlight and brakets and a pic of my 73 ATC70 with the DR ATV headlight and brackets. Remeber also that you are a 6 volt sysytem so get the correct bulb.
    http://www.3wheelerworld.com/showthr...C-70-headlight
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    Nov 2009
    N Hollywood/ CA
    588
    Thx Blue27, that's helps alot. I do have a tailight in the back of the bike. Can I use the current from the wires that connect to that to power up my front light?
