Results 1 to 14 of 14
Thread: " this guy ..... again !! "
    haggard 2hundie's Avatar
    haggard 2hundie is offline Would rather be at the front of the train than Arm chair racerJust too addicted
    muscatine, iowa
    764
    yup me again hahah so here goes checked valve clearance .003 check , t mark lined up on the flywheel check clean carb , petcock , and fuel lines , new air filter greased and oiled check , small crack in intake tube check ! heres what it does , starts fine and idles great ....on choke , no choke revvs real high , low r's good but sputters at full throttle my pilot screw is 2 turns out from a light seat .
    is the cracked intake the cause of the high idle ? and the reason it idles great on choke ? less air pulled when choked ? anyway , where to find an intake preferably new ? p.s. the main jet is supposed to be a 112 which is what i got i ordered a 115. where do i go from here ?
    Jun 2009
    Tunkhannock,Pa
    904
    cracked intake is most likely the problem because its sucking air in and causing it to run lean
    1985 200X
    66mm H&S Piston
    Little Bit Bigger Cam
    Bassani Exhaust
    1985 350X With Bassani Exhaust
    1983 Honda 200E (PARTING OUT!!!!)
    1985 Yamaha Tri-Zinger
    My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
    muscatine, iowa
    764
    thanks for the reply i hope your right i just wanna ride !!! and have my machine proper. how much for an intake ?
    Pafrig's Avatar
    Pafrig is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2009
    ALASKA
    278
    .....how much does a roll of duct tape cost?
    muscatine, iowa
    764
    Quote Originally Posted by Pafrig View Post
    looking for a more permanent fix but i guess if the tape seals it temp. it wil tell me fo sho if thats the isue.
    Apr 2006
    London Ontario, Canada
    1,197
    I've used silicon myself,
    Tapper
    R.I.P. Sandpuppie, you are greatly missed!
    May you rest in peace Jeswinehart, deeply missed, never forgotten....
    Feedback thread http://www.3wheelerworld.com/showthr...ight=tapper190
    1,736
    20 bucks, ebay. just checked. http://shop.ebay.com/?_from=R40&_trk...All-Categories
    choke makes your machine run rich, air leak makes your machine run lean. put them together it runs good, thats why she runs with choke
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,239
    you might want to check your pilot jet... usually if it won't idle or run without the choke on the pilot jet is plugged..
    muscatine, iowa
    764
    thanks everybody im not as bad off as i thought ,its a brand new carb but it did sit with some gas in it for over a yr and i think i got it all cleaned out before putting the new carb on still gonna pull the carb off tonight to have a look will rtv silicone do the trick ?
    Oct 2007
    Minneapolis mn
    4,067
    Heard of guys dipping them in the rubber dip it (for like plier handles) for a temp repair....
    Manitoba
    536
    I used black rtv gasket maker on my cracked boot. I'd like to replace it.
    Dried gasoline can leave a very tenacious residue that will defy many attempts to just wash it way. Once a passage is plugged, its hard to get anythign to flow through it to get the cleaning started. I would make sure you can blow through each passage to ensure its not blocked. Gas can dry as hard a paint.
    84 200x
    Jul 2006
    western ny
    3,366
    Quote Originally Posted by tapper190 View Post
    Tapper
    dito that ! ive also used eletric tape in a jam .. it got me home .. i have a spare 200x intake here if ya need one man ..
    GIT IT RAAAGGGGG !!!!
    muscatine, iowa
    764
    8200s how much for the tube ?
    Jul 2006
    western ny
    3,366
    pm me and we can work it out ..
