Thread: 110 engine/carb problems
    Crest California
    3,014
    I finally got the parts I needed to get my CDI 110 engine going. Thanks TheRealFatShady! Put everything in this afternoon, go to start it and nothing. So I futz around with the carb, and get it to fire over, but now the engine won't run at idle, or stay running longer than 5-10 seconds with throttle.
    I'm thinking it's still carb tuning and a spark plug? Any second opinions on this?
    LED obsessed
    2015 Yamaha FJ-09
    Jul 2006
    western ny
    3,366
    did you gap the plug ? you may need a new plug or adjust the idle some .. as for it stalling after 5 min with throttle you may need to adjust the air/fuel mixture screw .. seems to me like its not getting enough fuel .. could be a plugged fuel filter too .. im not much help without hearing it but im guessing its a carb issue .
    GIT IT RAAAGGGGG !!!!
    Crest California
    3,014
    Quote Originally Posted by 84honda200s View Post
    Well, it's 5-10 seconds, but thanks for the 2nd opinion
    LED obsessed
    2015 Yamaha FJ-09
    Jul 2006
    western ny
    3,366
    Quote Originally Posted by Xpress View Post
    oh lol well either way im still guessing carb issues ..
    Pafrig's Avatar
    Pafrig is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2009
    ALASKA
    278
    check that your both your jet holes are 100% clear. you should see a round hole of daylight.
