Page 3 of 3 FirstFirst 1 2 3
Results 31 to 44 of 44
Thread: Ford pickup motor swap questions
  1. #31
    put a cummins in it we have done it . My brothers truck have one bolted to a zf5 with 9'' of lift and 39s and getting around 22mpg on the highway
  2. #32
    The 460 is a much better motor when "built". The truck motors in stock trim are notorious gas hogs and although they will lug, they do not make impressive power.
    dirtbiken's Avatar
    dirtbiken is offline At The Back Of The Pack Arm chair racerFirst time rider
    Canada
    214
    um walkerallen I got a dodge. and dont worry about it, if I want to talk about Chevy's beating fords which everybody knows that they will I can. I dont see anybody stopping me. AND i GOT MY LISENCE TO.
    If its to loud then your to old
    I will see you at the finish line
  4. #34
    Quote Originally Posted by big specht View Post
    Now we're talking. I really wasn't planning on making this that much of a project, but I would love to do that someday. My buddy's dad is in the final stages of a Cummins transplant on his 04 F-350. It had the boat-anchor 6.0 diesel in it. Trucks gonna be sick when it's done.
    COLORADO
    685
    A 6.5 Detroit would do well also, put an NV4500 behind it and you will pull well and get good mileage. I would just look for a wrecked 302 powered F-Series and make a swap. I just redid the top end on my 5.0 powered Crown vic and got some good power out of it. Also I would ditch the smog pump also, just another intake leak IMO.
    You will cry, you will scream if you've heard half the **** I've seen.
    Are you gonna get up and burn an X in your head?
    "Cut throught the bone and cut through the wire"
    Trikes:
    84&85 Tecates
    85 R
    85 X
    Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
  6. #36
    PA
    3,515
    Yup, Im a 460 fan but I hate them in stock form. Or any common big block for that matter. My mild 400hp 460 gives me 10-12mpg and thats with an 850 holley....lol
    WWW.HREATV.COM
  7. #37
    Quote Originally Posted by dirtbiken View Post
    Why don't you go shim your starter or something. I'm sure you won't get that, so let me know and I'll explain it to you.
    Woodsrider's Avatar
    Woodsrider is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2009
    Eastern Passage, NS
    238
    I think he was suspended a couple days ago....you'll have to wait for his reply....
  9. #39
    Woodsrider's Avatar
    Feb 2009
    Eastern Passage, NS
    238
    I think the 460 is a great motor if it's built up. I don't plan on building it, and I'm not crazy about the 460 in stock form. All I might do is put headers and duals on it and maybe some small bolt ons. I always had a preference for the FE. There is aftermarket stuff for the FE, it's just more expensive. My 390 had a lot more balls than my 460.
    Let's not even get into the 351M's and 400's. There is a reason I didn't even list those as an option...
    I've sort of been following this thread(pure curiosity).....so I'm learning a bit about some Ford engines which is cool....if someone wouldn't mind explaining to me what FE refers to..I would appreciate it...you lost me on that one.
  10. #40
    Oct 2007
    Minneapolis mn
    4,067
    This is wikipedia, so take it with a grain of salt...
    "The Ford FE engine is a Ford V8 engine used in vehicles sold in the North American market between 1958 and 1976. A related engine, the Ford FT engine, was used in medium and heavy trucks from 1964 through 1978. The FE filled the need for a medium-displacement engine created by the discontinuation of the Lincoln Y-block V8 engine. The FE joined Ford's other V8s which included a small Y-block and the big block MEL engines.
    "FE" is an acronym for 'Ford-Edsel'[1]. Versions designed for use in trucks and school buses were known as "FT", an acronym for 'Ford-Truck', and differed primarily by having steel (instead of nodular iron) crankshafts, larger crank snouts and different distributors"
  11. #41
    PA
    3,515
    Quote Originally Posted by Thorpe View Post
    I'm not saying the dates are right but thats the info I always heard.
    WWW.HREATV.COM
  12. #42
    Oct 2007
    Minneapolis mn
    4,067
    Quote Originally Posted by Woodsrider View Post
    Managed to get himself banned according to the list... Looks like being a dink doesnt get you too far! Doesn't bother me though...
  13. #43
    RID3R's Avatar
    RID3R is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    VA
    399
    Have you found out if it does have a 460 or 351? Im in the middle of swapping a transmission from behind a 300 straight six to a 351..
  14. #44
    I haven't. The guy whos truck it is has been dragging his feet. I don't think he's in any rush to sell it.
