G'day all, how do you clean your air filter? Just with water and let it dry? Do you add oil or anything to the filter, before re-installing it :?:
Thanks
Thanks
I usually dunk it in gas, scrub it good to get all the dirt out and then rinse in gas. Let it dry and put some air filter oil on it. Not a lot but just enough for a thin layer all around it. If you get too much, then the engine will starve for air. hope that helps![]()
[20:55] <waterpumper> putting a racing pipe on a Foreman is like putting a high dollar bikini on a 400 pound chick...just because it fits doesn't mean it looks cool
I let it sit in a strong soapy solution to loosen all the crap, and then rinse it out from the inside. Once it's dry I re-oil and reinstall.
Thanks guys that's all I needed to know.
