Since Kasey and I are two stuborn old men who refuse to let the subject Die, lets have a little poll. I say if the poll favors Kasey i'll never speak on the subject again, IF Kasey agree's to the same.
i am sticking to the basic's and avoiding the off topic remarks
a member (Basket) asks about installing a CR 500 motor in a ATC 250R chassie.
Kasey explains his method and his experiance with his machine
MR ATC post a thread explaining that while Kasey's frame works and has had no problems it is not the best way to do the conversion. MR ATC also provides an alternate way to do the install Based on his experiance building them.
Kasey takes this as an insult to his design and fires off at MR ATC saying he has no proof of this.
MR ATC explains that although Kasey has had no problems with this if he ( MR ATC) were to ride the ATC he could probably brake the frame within an hour of hard MX use. He ( MR ATC ) said this knowing that it is indeed possible because he has broken stock frames that still have the brace in question
Kasey can't beleive it is possible to do so because it has not happened to him
MR ATC post a picture of a stock 250R frame damaged in the very same area in question.
Kasey still can't believe it is possable. it's good for him so it must be good for EVERY one else.
MR ATC NEVER said Kasey's frame was not good for him ( Kasey). MR ATC said HE ( MR ATC ) could brake the frame.
MR ATC ask's Kasey what does he (Kasey) think would have happened if his (Kasey) frame sustained the same kind of impact as MR ATC's 250R frame has sustained.
Kasey has yet to answer the question and dances around the question.
Basket list his 250R/500 frame on EBAY. it is built like Kasey's Frame.
it sells for a WHOPPING $9.98.
