Results 1 to 7 of 7
Thread: are the 250R rear plastics different 83-84/85-86
    Apr 2010
    central minnesota
    462
    So I just got an 83 R last night from the original owner but the plastics are not very good. I'm wondering if that style from 83-84 are different than from 85-86. Seems to me like they are but I may be wrong! Also, will a 86 front fender fit on the 83?
    Williamstown PA
    5,825
    83-84 is one style 85-86 is a dif, you can swap but like always you gotta cut up somthing.
    Apr 2003
    Bay Area CA.
    2,638
    Theyre completely different.
    1985 350x
    1985 atc70
    2006 ltz400
    2017 z125pro
    Apr 2010
    central minnesota
    462
    Is it possible to put the 85-86 on the 83-84 without having to do tons of mods?
    Williamstown PA
    5,825
    3wheelersforever did it.
    Southern MN
    1,875
    I'll tell you right now >>> Dont waste your time! They wont work, because the 83-84R seat comes down a bit in the middle, not a flat pan like 85-86. You would end up ruining your fenders to make it work. Still, if you did manage it, there would be gaps all over the place, between the seat and fender. Your best bet is to repair (plastic weld) your old fenders if there is enough there, or try to make a fiberglass mold out of them, or probably the easiers - buy the correct 83-84 fenders. I believe the 85-86 front fender would go on without issues. I have seen a lot of them used, especially on 200x's. Good luck!
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Apr 2010
    central minnesota
    462
    I just thought if it were possible I would go that route, since its not I will just get a set from dennis kirk. For sure using the 86 front fender though, looks so much better in my opinion
