atc 110 carb problems
The carb was working great, usually, even when cold, one pull would start the machine. One day it started wanting to die, as though fuel starved. I could jiggle the throttle and it would keep running. When it would die, it would take a short while/wait before it would start again. I came home and "fiddled" with it for a while. I got to where it would take 20-30 minutes before it would start, but would not idle. I pulled the carb, cleaned it as throughly as I could. The only problem I could see was a dirty fuel filter. I drained and flushed the tank checked all fuel lines, reassembled the carb and installed it. It starts well, but have to use the choke to start it now. However, I cannot get the idle correct. I set the pilot screw to manual specifications and started the engine. When I start the engine, it will idle satisfactorily for a minute or so then rev up to rather high rpm. When I try to adjust the idle, even with minute adjustment, it will rev down dramatically, and sometimes dies. I tried to adjust the pilot screw to adjust the idle, and it seems to do nothing no matter which way I turn it. It runs even when screwed all the way in. What do I need to check next, or what repair do I need to make. It is all completely stock (1985 model) and I can't afford to buy a new carb. Incidently, it runs an goes well when riding with no apparent carb problems. It is only at idle.
Thanks for any suggestons.
look for airleaks. intake boot seals end up being broken alot 0f the time and such
//ArrowChat Integreation Code
