Results 1 to 2 of 2
Thread: honda atc 110 carb problems
    Apr 2010
    Kildare YX
    I am having much trouble with my 110 carb. I cannot get it to idle. When I set it to factory settings, it starts and idles good for 30 seconds then will rev up. I can idle it down with the adjustment screw, but then the same thing happens. The pilot screw seems to have no effect. I have removed, cleaned and checked the carb throughly. I have checked all connections, flushed the gas tank. Checked the throttle cable and lubed it. What have I not done that I can do, short of replacing the carb. I have a very limited budget. Incidently, I rode it one time since this problem started with no carb problems until I stopped and shifted to neutral. Any Ideas/suggestions.
    1,736
    well instead of posting the thread again because you didnt get enough replys, just bump your original thread to bring it to the top again rather than spamming the servers.
    Like said in your original post check for airleaks
