Results 1 to 9 of 9
Thread: Evil 4 wheeler question
    Springfield Mo
    3,309
    I have a Honda TRX 90 with a noisy top end. I am pretty sure that it is a valve noise. I adjusted the valves but the noise did not go away. It is "clicking" like it is low on oil. I put the exact amount of oil needed in. Any ideas?
    Thanks!
    Sep 2007
    oregon
    2,292
    I would check the timing chain.
    Springfield Mo
    3,309
    To see if there is slack or what?
    Sep 2007
    oregon
    2,292
    yeah.........
    Willamstown PA
    5,822
    adjust the cam chain.
    Springfield Mo
    3,309
    Can someone paint me a pic. The cam chain is the same as the timing chain correct? If so, How do you adjust that?
    COLORADO
    685
    what about valve lash? my CT 90 did that and it was just loose valve adjusters. I thought those chains had an autotensioner.
    You will cry, you will scream if you've heard half the **** I've seen.
    Are you gonna get up and burn an X in your head?
    "Cut throught the bone and cut through the wire"
    Trikes:
    84&85 Tecates
    85 R
    85 X
    Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
    Jul 2008
    MD
    911
    Here is a link I found from someone else. Had a similar problem. The TRX90 has a automatic adjustment.
    http://forums.atvconnection.com/kids...-trx-90-a.html
    Springfield Mo
    3,309
    Quote Originally Posted by 86trizinger View Post
    Thanks, I will try and locate that, and see if I can make it a little tighter.
