Results 1 to 10 of 10
Thread: Thinking about a new project...(need some insight)
    Jun 2009
    Tunkhannock,Pa
    904
    After I finish my 200x I've been thinking about finding a 200x roller and try to do a Steve Wright factory racer replica. From what i can tell in the picture the frame has been redone to fit the 2 stroke engine and the tank had been cut back to fit the radiator and was fitted with 85 R shrouds. I figure I can get a set of repro low profile fenders from SKYKO and as for the engine does anyone know what type of engine was used. I imagine it would take lots of time to do but I think it would be really cool. What do you guys think
    1985 200X
    66mm H&S Piston
    Little Bit Bigger Cam
    Bassani Exhaust
    1985 350X With Bassani Exhaust
    1983 Honda 200E (PARTING OUT!!!!)
    1985 Yamaha Tri-Zinger
    My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
    84atc200's Avatar
    84atc200 is offline At The Back Of The Pack Arm chair racerFirst time rider
    new cumberland
    216
    I think it sounds cool.
    nitrodude81r is offline Check My Feedback before dealing with me Arm chair racerNew to the board
    Jun 2009
    Addison,Michigan
    63
    Sounds awsome!
    TF 09, 10, 11 Survivor
    81 250R- DG pipe,DG silencer, DG head, DG boost bottle, 34mm flatslide carb, UNI filter, Works shock, Nasa +5 axle
    85 Tecate-
    , but Airfoolers RULE!!!
    OK
    5,450
    Do you have a scan of the picture you can post up? I have some old 3wheeling magazines I can go through to look for more pics.
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    6,811
    I might have a few photos I can post . Will look later for ya .
    Jun 2009
    Tunkhannock,Pa
    904
    alright Mike that would be great i only have the one i found on here
    1985 200X
    66mm H&S Piston
    Bassani Exhaust
    Southern MN
    1,875
    A Suzuki PE 175 dirtbike motor will fit, and i've heard the motor nearly bolts right in! It is an air cooled motor though, but way more HP and snap than a stocker 200x. I dont know what all has to be done in order to make it work, but I remember years ago on here a guy did it, and it ripped! There should be a vid on youtube, I'll have to see if I can find it. ROOTS!!
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    OK
    5,450
    This is the best i could do..
    Rides:
    My feedback thread
    Williamstown PA
    5,825
    I was going to do this last year so i bouth a cheap set of oem R shrouds since that what i figured out they used but cut up some. it will take major mod work to the tank, the botteom of the frame is nothing the same as 200x, if you noticed the use all 250r geometry it looks.
    i had been talking with syko and he said he could do this, i just choose not to because after a test mock up the R shrouds looked HUGE!!!!!!
    Jun 2009
    Tunkhannock,Pa
    904
    yeah i noticed the bottom of frame is completely reworked and so is the tank but i think it would be pretty cool to give it a shot
    1985 200X
    66mm H&S Piston
    Bassani Exhaust
