I have a stock, beat up 250es. Needs tons, like plastics tank seat covered, cleaned up, battery, and I believe has low compression.
I was thinking of this:
400ex or 350x carb
Big bore kit - where can I find one? (Or maybe TRX 300 top end????, or high comp. piston kit)
Barnett clutch - don't want stock auto clutch slipping
Upgraded cam, not sure which to use
27-30" tires
Lift front and rear of bike, like the camo ones on here
Aftermarket exhaust - found supertrapp muffler from a 250sx, think it will fit nicely?
Is there anything else I can/should do? Basically I am going to put a lot of money and time into it to make it a GIANT monster. I have other 200s/similar models to use for regular stuff, so this is going to be my crazy, humongous mudder.
And is there any truth to rear ends going out/stripping out? I've heard this has happened to the TRx300'S with big rear tires? Not sure if there's any truth to it.
thanks and wish me luck
