Thread: 250R mixture ratio?
    May 2002
    Dublin, Georgia
    635
    250R mixture ratio?
    What is the correct fuel/oil mixture ratio for a 1984 250R? I just picked one up for $400, and want to make sure I mix the right amount.
    May 2003
    Shediac, New Brunswick
    1,126
    re:
    sweet deal..
    go 40:1
    '84 Honda 200x
    slow restro
    Rittman, Ohio
    6,276
    Re: re:
    Quote Originally Posted by short4stuff
    go 40:1
    Just wondering how you can recommend a mix without even asking what kind of oil he's running? Id strongly disagree with 40:1 across the board. Most synthetics and hi performance oils are intended to be run at 50:1, your Yamalube, Honda stuff and other factory oils run at 32:1 to 40:1, and your general purpose outboard 2 cycle motor oils should never be run leaner than 20:1 to 25:1. Proper ratio is determined by oil, and not by the bike model.
    Feb 2003
    106
    what would you recommend for castrol synthetic oil.
