I have an 83 250r and the stock pipe on it is shot don't know if i should buy an original one from ebay or an DG pipe I was also wondering what about a cr 250 pipe would that fit right on a atc 250r ?
A cr 250 pipe will not fit directly on an atc. If you want more power buy the DG pipe, they make a big difference, especially if you go to the bigger 34mm carb with it. Good luck finding a pipe.
TF 09, 10, 11 Survivor
81 250R- DG pipe,DG silencer, DG head, DG boost bottle, 34mm flatslide carb, UNI filter, Works shock, Nasa +5 axle
85 Tecate-
, but Airfoolers RULE!!!
