Thread: 83 2oox noise
    bartonsville
    23
    83 2oox noise
    there seems to be a slight tapping or clanging noise in the top end part of my motor at idle. you dont hear it when the rpms go up but only at idle. motor was recently rebuilt. is that valve adjustment or cam chain? if so how do you adjust and is it easy to do?
    Ask Monroe Mike for the FREE downloadable manual...... Then adjust both.
    Still have noise? it's probably worn chain guides: http://www.3wheelerworld.com/showthr...ng-valve-cover
    Nov 2007
    could be a valve adjustment issue. 84 2oox is .003 if i remember correctly. google 83 2oox valve adjustment. There is a webpage that will walk you thru it. Also check where your exhaust head tube meets the motor it could be a little loose.
    Manitoba
    536
    There's everything you need on this site!
    http://www.3wheeler.org/dirtwheels/6...neupindex.html
    84 200x
    Crest California
    3,014
    What's a 2ooX?
    Jk..
    LED obsessed
    2015 Yamaha FJ-09
