Thread: HELP with carb upgrade
    Apr 2010
    central minnesota
    462
    Exclamation HELP with carb upgrade
    ok guys, I got an 83 and it rips but im a big dude and looking to get as much power out of it as possible on a tight budget, If i had the money it would be a 480 swap or a big bore kit or who knows what! Anyways, I have heard that I can do i few slight upgrades to gain more power such as new reeds and reed cage, running a "naked" air filter, and upgrading the carb. The question here is what carbs am i able to put on this thing? thank you in advance!
    Apr 2010
    central minnesota
    462
    Really???!!! All this knowledge and nobody wants to share a little with me?
    atcrider1's Avatar
    atcrider1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2009
    Montrose MI
    400
    on my 82 i used a 38mm carb boot from a 600 yamaha sled with a boost bottle port, and a 36-38mm keihin pwk off a 90's kx 250 with a open uni filter and it runs great, i didnt even have to rejet it. what kind of exhaust do you have on yours? the new dg's are supposed to make a noticable difference. i will get one when i can afford it
    " I gotz the 8-track player mounted to my Oly, it's pretty sweet for trail side dance parties....."
    -Uller God
    Apr 2010
    central minnesota
    462
    I'm not sure what the pipe is, aftermarket for sure! Haven't had the trike long enough to research the pipe since it has no markings on it. I did however find a small stamping on the head pipe under the gas tank that says "sanken" I think it was, no clue about whether that was stock header or what!
