Results 1 to 9 of 9
Thread: 84 BR overheating possibly and died?
    Feb 2008
    Texas
    121
    So yesterday my girlfriend and i went on a about a hour ride on my 84 BR and 200s. after about 45 mins the BR started kinda bogging and died on her. So i stopped and it wouldn't turn over with the electric start and i noticed the motor seemed hot as hell. I tried to pull the rope to start it and a milky looking liquid came out when i pulled the rope and it hit my leg and was so hot it burned me. Checked the oil and it was fine so could it have been oil? Let it set for about 5 mins and it started right up with the electric start and we rode on home about a 10 min drive and was fine. Havent messed with it since any ideas what might have happened?
    85 200x
    84 200s my fav
    84 200es Big Red
    83 185s
    83 200x
    3 - 83 200e Big Red's
    84 110-sold
    82 250R-sold
    85 Tecate-sold
    85 250R-sold
    85 ATC70-sold
    plymouth,il
    1,231
    Mine will get hot too if I'm riding in mud or in real tight trails at low speeds where it doesn't get a lot of air flow on the head. I just shut it off for a little bit but and let it rest. Usually there are quite a bit of water crossings on my trails so It gets a little cooled off from that I would assume. I'd change the oil and see if that helps just to be on the safe side. The old big reds are really hard to kill so I'd say it's probably fine but I'm no mechanic.
    Life is better on 3 wheels
    1984 200es big red
    1976 suzuki rm125
    1983 honda 250r (minty fresh) SOLD
    1986 honda 350x (A PILE....for now)
    197? honda 90 (pauter framed little beast in the making)
    Feb 2008
    Texas
    121
    no one else has any ideas?
    85 200x
    84 200s my fav
    84 200es Big Red
    83 185s
    83 200x
    84 110-sold
    82 250R-sold
    85 Tecate-sold
    85 250R-sold
    85 ATC70-sold
    Manitoba
    536
    The milky looking substance is puzzling. Water and oil form a milky emulsion. If you are not seeing that in the crankcase, that's a good thing. But why it seized up on you is not good. I'm not familiar with Big Red's, but you should replace the oil and check the filter to see if you can gather any more evidence. Seizing indicates something serious, like a lack of lubrication or bearings that failed.
    84 200x
    Feb 2008
    Texas
    121
    it didn't seize it just started bogging and died, let it cool off a few mins and rode her home. haven't been in any water other than setting out in the rain.
    85 200x
    84 200s my fav
    84 200es Big Red
    83 185s
    83 200x
    84 110-sold
    82 250R-sold
    85 Tecate-sold
    85 250R-sold
    85 ATC70-sold
    plymouth,il
    1,231
    My big red gets water in it's pullstarter too that's why I can't pullstart it in the winter. It's not water-tight so it gets in there and stays I should probably take that apart and drain it now that I think about it.
    1984 200es big red
    1976 suzuki rm125
    Oct 2007
    Minneapolis mn
    4,067
    I would change the oil and filter... The white stuff is weird...
    Connecticut
    63
    Time to change the oil.
    The gluck you refer to is emulsified oil, that is to say you have water in the oil. This will be from either 1) engine has been used on short journeys which do not allow the engine to get hot enough for long enough and hence does not get the opportunity to burn off moisture, or 2) if you have a water cooled engine there may be a coolant leak. If you have a water cooled engine has the a drop in coolant level may be an in indication of coolant leak.
    Suggest you drain the oil, clean the motor with engine flush, drain, put in fresh oil and a new filter.
    Owned:
    1985 ATC 200s - SOLD
    1985 ATC 250es Big Red - Resto to begin this week :-P
    1983 ATC 200 - SOLD
    "2 wheels not enough, 4 wheels too many, 3 wheels just right"
    "A buddy of mine had a trophy wife... But she obviously wasn't first place."
    "LOCK IT UP!!!"
    cbx1170's Avatar
    cbx1170 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Phoenix AZ USA
    224
    Not engine oil area. Your recoil area has water in there. Drain is plugged. Could poke up from bottom at edge of recoil it will come running out. But only part of it. Water turns tan milky from being in electrically charged & dirty area. When electric items like stators (that have 2-3 kinds of coils like charge coil, lighting coil, source coil) pulser coils at camshaft, suppresor caps on sprk plugs get hot they increase resistance and fail from heat. Sometimes permanently, some short time. You have boiling hot water mixed with mud and rusty gunk filling your recoil area. Electrics not designed to work semi-submersed. Serious corrosion is also happening. It prolly got so hot it shut off ignition via one or more coils. take recoil off drain clean reassemble and make sure drain is open at bottom. unless you are water/mud bogging it a lot. Worse case scenario - derust whole area and prob use puller to remove flywheel/rotor to get it properly clean as much hides inside rotor/stator area and may cause drag. Lube recoil center bush/shaft also. I have even lightly sand blasted (careful!) some bad ones to get bike to run again. Post is long cause its a bit to explain. MRC
