Decided to try and rebuild my 83 250r. just wondering how far i can safely overbore it? thanks for the help
Check out wiseco website: http://www.wiseco.com/ProductSearch.aspx
'84 ATC 110
'84 200x
'85 350x
'86 125m
'03 Shadow ACE 750
'05 Brute Force 650
It really depends on how much it has been bored in the past? If the cylinder is on it's original bore you have room for several more, unless the bore is scarred or grooved really bad. If the cylinder is on it's last bore, you will need to sleeve it.
Rides:
1982 ATC70 (Lifan manual 125)
1987 LT80 (piped, widened)
My feedback thread
RIP Trace.. Godspeed.
Its .010 over at the moment.
You can bore it out to .080. But if you are only at .010. IMO go to .020 or .030 depending on how the cylinder looks.
TF 09, 10, 11 Survivor
81 250R- DG pipe,DG silencer, DG head, DG boost bottle, 34mm flatslide carb, UNI filter, Works shock, Nasa +5 axle
85 Tecate-
, but Airfoolers RULE!!!
