Results 1 to 8 of 8
Thread: 1985 250ES Carb plunger (choke) any kits come with one?
    Worcester, MA
    1,117
    Been doing some work on the cold start issue, I suppose I can drill my starter jet out to .80 if it is a problem, but need to address choke issue first.
    My plunger is seized/rusted in place. No force/penetrating fluid will free it. Will have to carefully drill it out.
    I am having a hard time finding a kit with this choke plunger in it? Anyone know where I can get one?
    I may just drop in a TRX300 engine and 350x or 400ex carb, but for the time being I'd like a stock setup to be fully functional
    Thanks
    haggard 2hundie's Avatar
    haggard 2hundie is offline Would rather be at the front of the train than Arm chair racerJust too addicted
    muscatine, iowa
    764
    have you checked out any moose kits ?
    Worcester, MA
    1,117
    Yep, they seem to be the most commonly used and most commonly available, didn't see a plunger in the set. Just gaskets and jets.
    Oct 2007
    Minneapolis mn
    4,067
    No they do not come with them... And they are expensive... 45 dollar range...
    Worcester, MA
    1,117
    From what I've read, I need this:
    16046-HA0-013
    Located here:
    http://www.cheapcycleparts.com/produ...ve-set-starter
    Part diagram, number 9:
    http://www.cheapcycleparts.com/model...duct_id=285511
    Looks like I may have to shovel out that money for it. I think the TRX300 engine I am picking up may run, but had that same problem with the carb. Would hate to buy it for my stock carb then buy it again for my TRX Big Red.
    ailll1's Avatar
    ailll1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2009
    Québec
    405
    I bought a used SX(same as ES) carb from ebay couple months ago.
    Was seized everywhere!
    But what i did to get the choke plunger is I unscrewed the plastic part which gave me a little space to spray paint thinner into it.
    Let it sat for an hour or so and came out loose.
    Did same with pilot screw.
    1985 ATC250sx
    1984 ATC200s
    1984 ATC200x
    HONDAS FOR LIFE!!!
    Worcester, MA
    1,117
    Was it usable after that?
    ailll1's Avatar
    Dec 2009
    Québec
    405
    Of course it was! The plunger and needle came out without any damage, only fews color changes, lol.
    1985 ATC250sx
    1984 ATC200s
    1984 ATC200x
    HONDAS FOR LIFE!!!
