Results 1 to 2 of 2
Thread: 200es with xr200?
    new hampshire
    7
    200es with xr200?
    sp yea as the title says feasable? bad idea? i read on here something about the xr200 motors being almost the same as the atc 200 engines? true false? should i get another frame to start with ?
    Worcester, MA
    1,117
    Aren't the 200es shaft drive?
    You would want a 200s, 200m, 200, 200x, 185, 185s.
    Then you would want the kickstarter gears from a 200x engine, as the kickstarter on the XR200 kicks backwards and would hit your fenders.
    I have frames if you need them, located in MA.
