Results 1 to 15 of 15
Thread: How to clean oil out of a muffler?
    Jul 2008
    MD
    911
    I am trying to figure out how to clean oil residue out of my ATC muffler. Top end was rebuilt but blow-by put a lot of oil in the muffler. It smokes once it warms up. as been ridden 10 hours and still does it. How to I clean it out?
    Sep 2007
    100mi west of Chicago
    3,582
    Wow 10 hours and still doing it? I had the same problem after rebuilding my 200x but it only smoked for an hour. There was goo coming out the end of the muffler then it stopped.
    Rob
    Apr 2002
    s.w. michigan
    6,498
    Build a fire and put your muffler in it, that is how I have done the ones I have had to "de-goo".
    cox's Avatar
    cox is offline Just Too Addicted Arm chair racerJust too addicted
    Aug 2009
    Edmonton alberta canada
    552
    ^^^ Rednecking it, FTW!!^^^
    R.I.P. Yamahondaman
    Still practicing my NoobiX cube, take it easy on me...
    1982 Yamaha YT175J ( Not much left but the 's)
    1982 Yamaha YT175J
    1983 Yamaha YT125K + 175J =
    1984 ATC 200ES BR - running again - Camchain noise holding me back....
    1984 ATC70 -SOLD-
    leroy, new york
    1,025
    jeswinehart is right, it works.
    Apr 2002
    s.w. michigan
    6,498
    Big fire vs. little fire
    Quote Originally Posted by cox View Post
    what is FTW ???
    Anyways, if you don't want to build a big fire, a little hot one will do just fine.
    Although not as soaked as some mufflers i have had in the past, it will be interesting to see what the weight is after it has cooked over night.
    john
    Beaver Falls, PA
    2,666
    Quote Originally Posted by jeswinehart View Post
    what is FTW ???
    john
    FTW= "for the win", meaning it's the best solution, etc.
    Jul 2008
    MD
    911
    I have an xr70 muffler I will try first.. I have a large pile of brush for a fire anyways.. Might as well try it. I can weigh that pipe before and after to see what the difference is.
    Williamstown PA
    5,825
    was the top end rebuild correctly measing oil rings up the right way? i would just fill it with gas and light it on fire, then paint it after words. you could also use a tourch from lowes or somthing.
    Texas 200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Corpus Christi, Tx
    296
    Why not soak it in solvent?
    Hey, What other dangerously fun vehicles can I Cram in my 2and1/2-car shop? (Garage.)
    Frewsburg NY
    1,169
    I always soak it in cider. That is the best way I have found to clean out my pipe
    Apr 2002
    s.w. michigan
    6,498
    burn method
    Yep, this muffler was I burnt off was not very much "goo'd" up at all. It had quit smoking by the time I was ready for bed.
    Others i have burned off smoked untill the next day.
    Southern MN
    1,875
    FTW - For the win? More like F*** the world!!! Dont forget to pull the insert on the end, and install new muffler packing. If all the packing is gone/burnt out the machine will actually lose power in the low end torque range, and make the machine louder.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    here
    1,336
    I caught it Johnny's X, Your a card, lol!
    cbx1170's Avatar
    cbx1170 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Phoenix AZ USA
    224
    ? Clean your 2 stroke (pipe) silencer muffler. might work for 4 strokes never tried it ... just ran 4 strokers hard for 2 weeks and it slowly stops. STEEL 2 stroke remove all plugs caps screens baffles etc from muff. oxy/ace torch. build heat at one end/spot. get it smokin good. dont burn a hole. shut of torch ace leave oxygen running at low press.... play with it. put tip in one end use a rag to wrap plug the hole around torch tip if ya want. set ouside wait 1/2 hour pipe will have burnt from one end to other. watch the burning spot move. Kool. really smokes. tap out crusty "coke" residue. now its lite weight and "modified". cleaner than bonfire. paint? . assy and ride hard. ALUMINUM a little tuffer as it MELTS at 1200 F.
