Tecate wiseco piston 439 same as 431 ????
Ok Wiseco 439 series piston is for all Tecates 3 and 1978-86 KX250.
Wiseco 431 is for 81-84 ATC 250R Honda.
I open my 1986 KX250 top end and find a 431 piston and a needle falls out of the wrist pin bearing.
Ok I think this is the wrong piston cause its is all sloppy and not machined to be near the small rod end.
Order a NOS (old wiseco box) 439 and inside I find the same 431.
This can't be a coincidence. I realize they machined stops for the bearing but its so sloppy.
So is this 431 piston correct?
Is the 81-84 ATC 250R piston the same as the Tecate piston or are they machined different (windows, ect.)?
86 T3
84 T3
86 KX250
//ArrowChat Integreation Code
