Results 1 to 15 of 18
Thread: 1986 250r disaster
    virginia
    6
    Post 1986 250r disaster
    i have a 1986 250r i bought it from my uncle and he parked it like in the 90's and i cant kick start it it wont go down i don't know what to do can you help me ok so to day i was taking the right crank case cover off to see if the gear were jamed and when i was tighting the cover back on it crack now what do i do i bought some jb weld it that going to do the job.
    Crest California
    3,014
    What? Huh? Where's the proper sentence structure??
    LED obsessed
    2015 Yamaha FJ-09
    Nov 2009
    1,147
    Ouch. Don't over tighten anything. It's all aluminum. Just use a little 1/4 in ratchet. Also sounds like it might be seized up. If you can't kick it over, first thing to check is the rings and the cylinder. Pull the spark plug and shine a light in there. If its all rusty that's likely the problem. Fill the cylinder with penetrating oil and let it sit for a few days. If you are working outside put the spark plug back in. Take it out 3 days later and see if it turns over then.
    Service manual are located in world class help. A service manual is great. Read what you are going to do before you start doing it. And print the whole thing.
    virginia
    6
    i took the spark plug out and i took the bolt out so i could see the piston and the piston was at the bottom of the cylinder my dad said it doesnt suspose to be at the bottom but i will lube it up and see wat happend and wat about the crack crank case cover
    Mar 2008
    EastGreenbush, newyork
    3,494
    jb weld sucks!! Might work, but will look like crap. scour e-bay or the classifieds for a new cover. Invest in a 1/4" torque wrench!!!And use the manual!! these parts are 25 yrs old, and long discontinued, so careless mistakes can be costly!! good luck!
    Dec 2002
    374
    stop messing with it now and get an experienced mechanic to fix it. It takes some knowledge and experience to work on these machines and it sounds like you could use the help
    Mechanics rule#1 - Never FORCE anything. Bolts do not pull assemblys together, something was not lined up.......
    Dec 2006
    St. John's Newfoundland
    1,587
    So thats what I does wrong. lol. Joking that is awesome advice tho. I am guilty sometimes.
    1986 ATC 250r
    1985 ATC 250r
    1985 X2 ATC 70's
    1985 XL 80
    virginia
    6
    i took the whole head off and i fixed the cover with jb weld it work great but when i took the head off i saw that the piston crack and the reason the motor wouldnt turn over is because the crack peaces fell in the engine now i got to take the whole engine apart and where does it tell y what size piston because i dont know if my uncle got it bored out where does it tell you the piston size
    COLORADO
    685
    the crown of the piston should reveal the STD mark or overbore.
    You will cry, you will scream if you've heard half the **** I've seen.
    Are you gonna get up and burn an X in your head?
    "Cut throught the bone and cut through the wire"
    Trikes:
    84&85 Tecates
    85 R
    85 X
    Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
    OK
    5,450
    Or you will have to measure the bore with a bore gauge and micrometer. If the bore is scratched or has grooves in it you will have to have it bored to the next (over)size.
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,239
    IF IT HAD A MELT DOWN,, YOUR IN FOR SPLITTING THE CASES TOO.. main bearings will be junk too.
    virginia
    6
    look like i came to the right place thank you to all the 3 wheeler fans who helped me if i have and more question i will post them here
    West Central Wisconsin
    17
    Hey leecox.............If you ever decide to give up on this one i know a good home for it, my shop, just kidding, but really you should get a manual, they are a max of 30 bucks on ebay and they have a PRICELESS list of mechanical operations inside. I bought one for every vintage machine i've owned, no matter how many wheels, and they are worth every penny. Good luck with the 250r its been my dream since birth to own one.
    Feb 2009
    michigan
    2,387
    there are free manuals right on this site.please use them.that is the best threewheeler ever made dont jack it up please
    1985 ATC 250R
    . Team Red Trike
