Results 1 to 15 of 20
Thread: How hot is to hot ??
    haggard 2hundie's Avatar
    haggard 2hundie is offline Would rather be at the front of the train than Arm chair racerJust too addicted
    muscatine, iowa
    764
    o.k. so ive done a thread search and i understand that my machine ( 86 200X ) is air cooled, but it just seems to get extra hot quick ! i took a nice hour or so ride on the gravels near my house , wearing shorts , i know i know tsk tsk anyway my leg was getting slightly burned from the excess heat coming from the head , almost like a sunburn and i could feel the heat all around me coming off this thing.
    so i guess my question is how do i know if its too hot ? and what may cause extra heat , aside from a lean condition ? and what is the worst case scenario from running too hot ??
    Oct 2007
    Minneapolis mn
    4,067
    Worst case... BLOWN MOTOR....
    Feb 2009
    Rome,NY
    1,046
    when a air cooled motor gets too hot it starts to perform crappy the idel raises and ultimately will die .... best case cenerio you let it cool down enough and it will start back up and no damage. With shorts? yes it will "feal" hot
    Blossvale NY
    4,563
    along with the obvious things like low or incorrect oil, incorrect jetting, incorrect valve timing can contribute to overheating. check jetting first. if it has some aftermarket stuff like a better air filter and exhaust on it, it would need to be jetted a little fatter and would run hotter if it wasnt jetted accordingly. if the jetting is good, verify that the valve timing is correct. i have seen cases where the valve timing was off a tooth or 2 and the machine ran, but ran hot....
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    muscatine, iowa
    764
    thanks guys it has a uni filter and i think its a cobra pipe , i upped the main jet to a 115 from a 112 and it runs good , and i have checked the valve clearance and aligned the t mark with the index mark on the flywheel cover. do i need a tach. to check timing ?
    Blossvale NY
    4,563
    well, if you went from a 115 to a 112 main, you actually went leaner. i would put a 125 main jet in, and raise the needle one notch to richen the midrange a bit to compensate for the pipe. a 4-stroke motor can still run "good" even if the mixture is on the lean side. but it will run hot. they arent as quick to let you know you are lean as the 2-stroke motors are. as far as the timing, you are correct to check valve clearance when at top dead as you did, but to check valve timing, you need to remove the rocker housing. once removed, you will see to marks on the face of the cam gear that are positioned 180 degrees from one another. when the flywheel shows the "T" in the window, those 2 index marks on the cam gear should be parrallel with the top of the cylinder head. HOWEVER, i dont think this is your problem since you have a leaner than stock main jet in place while using an upgraded air filter, and especially the upgraded exhaust system. my friend (who goes by Chillian here on 3ww) had the exact same issue you are describing with his 250sx. he is running a stock motor, with a K@N filter and full Cobra exhaust. jetting it richer made all the difference.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Oct 2007
    Minneapolis mn
    4,067
    Agreed with RR^^ that I would still jet the high end a bit fatter... But you are stillneeding more adjustments than what you have done to it... Have a read...
    http://www.3wheelerworld.com/showthr...Jetting-Theory
    cbx1170's Avatar
    cbx1170 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Phoenix AZ USA
    224
    Its June temps are hotter. Heat takes more time to scrub off. Need air flow across fins all the time. Its called Delta temp diferences. And in general cyl head temps rise a little. Spark plug heat range? Correct plug? Cyl head temp gauge with temp sensing ring in place of spark plug compression gasket will give you exactly how hot head is getting, if you really want to know. I've seen air cooled 4cyl bikes run fine in PHX AZ in July at stop signs and stop and go driving also. Heat to the legs YES.
    ailll1's Avatar
    ailll1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2009
    Québec
    405
    In fact he said that he went from 112 to 115 which is richer just in a different order.
    Better go back on school bench
    1985 ATC250sx
    1984 ATC200s
    1984 ATC200x
    HONDAS FOR LIFE!!!
    Blossvale NY
    4,563
    Quote Originally Posted by ailll1 View Post
    your absolutely right! lol! i completely misread that.
    but i still stand by my recommendation to start at 125.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    muscatine, iowa
    764
    sorry for the confusion i think i have a 118 and maybe a 120 main still , ill try them ? but if i order any more parts this month i think my ( pregnant hormonal ) girlfriend will castorate me hahaha
    should i still try raising the needle?/ by lowering the needle clip ?
    litebulblsc's Avatar
    litebulblsc is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2009
    LaSalle, MI
    313
    I ran a 200s wit open header and open carb with no need to change jetting. I was still at factory carb settings and the thing ran good.
    And a red 2000 silverado
    Tionesta, PA
    5,747
    Does your 200X have a heat shield on the head pipe? If not that is normal to feel that - I have actually gotten a pretty nasty burn from riding my Big Red with no heat shield and in shorts - no contact was made - just radiating heat. Seems normal if you ask me. A good heat shield will eliminate some of that heat on the leg feeling.
    muscatine, iowa
    764
    no heat shield but i will look into one soon as soon as im off ebay , dennis kirk restriction i know i know el whipped o ! but hey there are certain things a woman can do that my 200X cannot ( without a terrible burn )
    Richland WA
    808
    thats what weak ignition does.
    Engine temperatures cannot be more than the max operating temp for the engine oil. Thats hard to measure. Cylinder head or engien parts shouldnt go over 180-200F as a SWAG, thats where water cooled units operate.
