My headlight and taillight are very dim on my 84 200x. I removed the tail light from the wiring and measured the voltage as only 5 volts. I then unplugged the headlight and it jumped up to 6 volts. I then measured the voltage at the headlight and its also only 6 volts (high or low beam). It will light up the headlight, so its putting out some current at 5 volts, but not proper voltage. The wiring diagram looks pretty simple for the stator coil, its just a coil, grounded at one end and putting out 12v ac at the other. If I had to guess, I'd say the coil has shorted to the laminate core somewhere along its length and now is only half lenght active.
Anyone have a stator coil go on them? Did it simply put out reduced voltage like I'm experiencing?
