Results 1 to 8 of 8
Thread: Air tool gurus need your help
    Sep 2007
    100mi west of Chicago
    3,582
    I've had a Craftsman 33 gallon upright air compressor since last fall but haven't used it all that much. Can I use a 1/2" impact wrench with it? I don't want to buy one if it is going to go pfft when I try to use it.
    Here are the relevant specs of my compressor from the owners manual:
    Running HP: 1.6
    Approx cut-in: 120 psi
    Approx cut-out: 150 psi
    SCFM @40psig: 6.3
    SCFM @90psid: 4.9
    Rob
    na
    5,702
    I have one of those and it will run impacts air s, die grinders and air ratchets.
    However, you will only get about 80% of the full power of a 1/2 impact with a compressor like this.
    The SCFM rating is what really matters on a air compressor.
    The higher the SCFM at 90 PSI, the more power you get to run the tools.
    It should work fine for lugnuts on cars and the occasional stubborn bolt and nut.
    If you get a impact that is rated to 800 Ft lbs of torque, dont expect to get all that out of it, with a light duty compressor.
    Proudly NOT a member of
    "Team on the Teat"
    PA
    3,515
    What mosh said is correct.
    Make sure you get a gun rated higher then you need so it will do what you ask of it. check out the Ingersoll rand titanium guns, I wont use anything else now that i have one.
    WWW.HREATV.COM
    Oct 2007
    Minneapolis mn
    4,067
    And use large diameter air hose.... Small dia. hoses will reduce your tool power...
    squirrel1182 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Derry, Pennsylvania
    253
    We have one of those small 6 gallon compressors that my dad uses for work and i use a half inch impact with it all the time.
    1983 KLT 200 C
    1978? YZ 125
    1978 Panther 5000
    1939 Farmall A, 51st farmall A ever produced.
    1946 International A Industrial
    1973 Ford F100
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    Quote Originally Posted by SWIGIN View Post
    i dunno man, the 1/2 NitroCat (1000 ft. lbs) and the 3/8 AirCat are some damn nice impacts. Lightweight, durable, and lots of power.
    Your compressor is good for everything but a sandblaster (pretty much).......
    It will work with a cabinet on smaller items as long as you let it build back up or use a large holding tank....
    Make sure it cools off ever so often if it's used allot and gets hot - DEEPA helped me learn that
    COLORADO
    685
    Watch out on that compressor, the compressor ring goes out often, otherwise they work great. I used my full steel IR 1/2 Impact with few problems.
    I am running two 60 gal compressors, a Sanborn and a Coleman, and my sandblaster still is weak. I guess I need either more media or more PSI on the manifold, I'm at 100 now.
    You will cry, you will scream if you've heard half the **** I've seen.
    Are you gonna get up and burn an X in your head?
    "Cut throught the bone and cut through the wire"
    Trikes:
    84&85 Tecates
    85 R
    85 X
    Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
