Results 1 to 8 of 8
Thread: How do I tell the difference between 200m and 200s forks
    plymouth,il
    1,231
    I bought a set of forks they were supposed to be honda 200m forks but I now think they are from a 200s the bottom of the triple tree is stamped S a carrot sign like this ^ but bigger then 21. I would measure the distance between the shocks but I took them apart to replace the seals before I started having my doubts. The side of the shocks say Showa 958-003. thanks.
    Life is better on 3 wheels
    1984 200es big red
    1976 suzuki rm125
    1983 honda 250r (minty fresh) SOLD
    1986 honda 350x (A PILE....for now)
    197? honda 90 (pauter framed little beast in the making)
    6,801
    Side by side one should look about 1 1/2" shorter than the other .
    Mar 2008
    EastGreenbush, newyork
    3,494
    the 200m forks are wider, than the s forks,the m runs a 25x12 tire, and the s a 22x11. also one is a leading, and one is a trailing axle, not sure which, but i can check when i get home
    plymouth,il
    1,231
    I don't have both of them side by side and I know what tire size they run. The 200m is a leading and a 200s is a trailing 99% sure. When it came to me it was set up to be a leading, but someone could easily just turn them around. heres a pic of when they were together from the seller.
    1984 200es big red
    1976 suzuki rm125
    Dec 2007
    Quebec,Canada
    1,014
    Check the microfiche for the 200m and 200s
    The 200m shock are different,the brake are on the right on both model,but the 200m axle bolt is in front of the shock tube,the 200s bolt behind the tube
    The 200m brake panel is made of steel,the 200s is a molded casting
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    Western PA
    84
    Looks like M forks to me. Side by side shot of the 200S and 200M here: http://www.3wheelerworld.com/content...Technical-Data
    The S is on the left. Both have a "nub" on the inside of the right fork and a bolt hole for the brakes. You couldn't turn them around and keep the nub inside where it belongs.
    plymouth,il
    1,231
    Ok thanks for all the help guy I confirmed it is a 200m fork assembly.
    1984 200es big red
    1976 suzuki rm125
    Sep 2022
    Maine
    After searching around for more data on this subject, I decided to make a completely new thread being this one is over 10 yrs old. I'll be in Trikesylvania...
