Results 1 to 15 of 18
Thread: engine degreaser
    Walkerallen's Avatar
    Walkerallen is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2009
    Wright City,MO
    313
    engine degreaser
    what is the best engine degreaser you have used?
    Feb 2009
    michigan
    2,387
    if you have access to a steam machine that is the best
    1985 ATC 250R
    . Team Red Trike
    Dec 2009
    Wright City,MO
    313
    i dont. im looking for spray on products.
    84atc200's Avatar
    84atc200 is offline At The Back Of The Pack Arm chair racerFirst time rider
    new cumberland
    216
    I always have used purple power. It comes in a gallon jug.
    Dec 2009
    Wright City,MO
    313
    what about dp engine degreaser? has anyone ever tried that?
    Sep 2007
    100mi west of Chicago
    3,582
    Simple Green works well and it's non-toxic
    Rob
    Dec 2009
    Wright City,MO
    313
    thats what i have herd. does it cut through mud, oil, and grease?
    Sep 2007
    3,582
    Yeah it's mean to be diluted but I use it full strength out of a spray bottle with an old toothbrush
    Rob
    DESERT HOT SPRINGS CA
    11
    Super clean cut grease instantly when you spray it on. Walmart sells it
    Frewsburg NY
    1,169
    Best engine degreaser you will find anyplace is at your local grocery store. Oven cleaner. Get the foam stuff and soak it. You will be amazed how well it works. I use to use simple green and purple power and all the name brand stuff. I will use nothing but oven cleaner now. Its amazing
    Crest California
    3,014
    Yeah the cleaners meant for the kitchen work great, stuff that lifts grease up. Simple Green and Dawn both are great at removing grease and dirt
    LED obsessed
    2015 Yamaha FJ-09
    6,811
    Formula 88 is also pretty good .
    Crest California
    3,014
    I wonder if Kaboom would work.
    LED obsessed
    2015 Yamaha FJ-09
    Pacific NW
    4,255
    I started using oven cleaner from the dollar store.
    Super cheap, well, a dollar..
    and mis thinking it MAY be comapatible with cooking bacon
    or brats on the exhaust manifold.
    read the directions,
    it might say to keep away from rubber and plastic.
    I warm up the engine and CAREfully spray it where I want it to go.
    Let it sit a bit, restart the engine and gently spray it off
    so I can see if/where the water stream kills the engine
    and find the weak electrical places on the trike.
    If it's warm when it dies, it'll prob dry enuf from being
    warm (NOT hot)
    I know, just don't get them dirty!
    TexFest's Avatar
    TexFest is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2002
    U.S.
    339
    the car wash
    TPC 450R
