Thread: 250r
    lower michigan
    32
    250r
    Hey just bought a chain and spoket set for my 250r and while chainging them i noticed my back sproket was a 37 and my new one is a 39 tooth sproket. i was wondering wut difference this will make and how much of a difference.
    Thanks
    Central NY
    121
    It will take away from your top speed probably around 4 or 5 miles an hour or so, But you will gain more low end, it will pull harder. Make sure you readjust your chain tension.
    Own 86 250sx
    85 350x
    sold 86 250sx
    110, 185s, 200s, 250es
    Project 85 250r
    If everyone else is looking down at you, Get a ladder..
    Oregon
    2,471
    13 / 39 is Stock set up ( perfect for all around riding )
    Make sure you mount the front Sprocket correct, I have seen lot's of front sprocket mounted backwards the Spacer Face in towards case's.
    If you mount it wrong it will grind a large groves in your case.
    Richland WA
    808
    you didnt say what the front was, and it makes more difference since its a smaller diameter.
