Results 1 to 2 of 2
Thread: Hi from Nebraska...
    Nebraska
    105
    Hi from Nebraska...
    Hey there guys/gals...just droppin' in to say hi...So far, have LOTS of toys but just bought my son a little '77
    Honda 90...need some advice with it...I got it running and it did ok up to about 1/4-1/2 throttle and then
    would cut out and sputter (no power past half throttle)...took the carb apart and cleaned it up good...all
    passageways are open...getting gas into the bowl...now it won't start...getting excellent spark...I even
    sprayed a little starting fluid where the air intake is and it won't even fire...any ideas? I blew air through
    every single opening in the carb, including the large and small jets...Do I need to adjust the little clip on the
    needle one way or the other? I turned the gas screw on the outside out 1 1/2 turns and kept going out 1/2 turn each time and
    nothing...If I'm getting spark, I'm assuming the points and the little jobby under inside the frame are ok...
    Just dumb founded, please help me out...Thank you!
    Ryan
    oregon
    668
    welcome to the boards.
    the common cause of your problem is the wrong size main jet.
    my 200x did the same thing but it could be a number of problems...
    This is my trike.
    There are many like it, but this one is mine.
    My trike is my best friend.
    It is my life. I must master it, as I must master my life.
    Without me my trike is useless.
    Without my trike, I am useless.
    I must roost faster than my enemy who is trying to beat me to the finish.
    I must beat him before he beats me.
    Before God I swear this creed.
    My trike and myself are defenders of track.
    We are the masters of keeping quads the losers.
    So be it ... until there is no quad left.
