Page 2 of 7 FirstFirst 1 2 3 4 ... LastLast
Results 16 to 30 of 95
Thread: old school 90/110 parts.
    Baltimore, MD
    6,088
    Are they just cranks or cranks with the right con rods as well???? And what size pistons?
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,250
    I WILL GET PICTURES... the crank is a complete unit crank new bearings and rod , ready to install,,, these were built by helm&sons back in the day... they are still in the original boxes. AND since its az no RUST!!
    6,816
    I THINK THERE IS A CASE OF THOSE PISTONS IN THE BACK... wow thats alot for a old piston,.,, so if i have 20 of them i can buy another trike if i sell some!!! i was thinking alot less than that...
    That piston kit has been for sale for a while now so dont get your hopes up . A realistic price on that should be around 65-75 bucks . Check and see if the kits have a 1 piece or 3 piece oil rings and what sizes they are 53-56mm .
    Baltimore, MD
    6,088
    I would be interested in a crank if you have several for sale. And congrats on your daughters engagement.
    Nicholson 185s
    KASEY's Avatar
    4,250
    BELIEVE ME I DO NOT INTEND TO try and GET RICH OFF THIS FIND. I am just excited to be able to have some old school parts and hope i can find enough to share with the community,,,
    Ripley Tn
    1,363
    Yeah like shortline said that kit has been on there for a while theres another pk kit on ebay as well for the same price, I would die for a stroker Im goin to go look at a 1980 110 today instead of this 83 I have
    85 Atc 70
    86 Atc 125m
    85 atc 350x
    86 atc 250r
    86 Atc 250r TT build
    85 Big Red bought brand NEW
    2012 Honda Goldwing Gl1800
    Baltimore, MD
    6,088
    I know the members on here aren't aware of you superhuman abilities to find deals. I'm sure they have never seen a pile of fiberglass atc70 racing fenders either. Or mounds of aluminum wheels. Some of us know what you have found in the past though.
    Nicholson 185s
    KASEY's Avatar
    4,250
    ok here are a couple of pictures.. i think there are enough cranks for everyone that wants one ,, and the cam in the box,, there is 30 of those.. the h&s cams are the only and are already spoken for. i did find enough parts today to build me a stroker big bore motor,, so i was happy.. So i know what i have to pay for the cranks. i know they are old school. and i am not trying to get rich.. SO some of you guys that want one,,, PM me with what you think they are worth to you ,, and we will see if i can buy all of them at a lower price . there are 58 mm and 61.5 also cam chains in 86 and 88 links.. also can these cranks be used in a 125 m motor?
    Aug 2005
    Lockport, NY
    2,395
    Kasey I'd love a set of them wrenches. Can you PM me please?
    6,816
    These strokers are most likely for the points models and not cdi . Easy way to check it , points takes a bolt to hold the flywheel and the CDI uses a nut .
    I dont think you could put one in a 125m for this reason also .
    Any of those S&W valve springs gonna be for sale ?
    Baltimore, MD
    6,088
    Now if you really want to make me happy, tell me you found some heavy duty oil pumps!!!!
    Nicholson 185s
    Feb 2003
    Australia
    927
    The 125M crank is different on the flywheel side in length and diameter (I am talking about the crank LOL).There is rod length issues as well.
    Ripley Tn
    1,363
    I like to have one of them cranks I pm'd you, this is sweet see all of the old 90/110 parts
    85 Atc 70
    86 Atc 125m
    85 atc 350x
    86 atc 250r
    KASEY's Avatar
    4,250
    OK. I WENT OUT ON A LIMB HERE.. i made them an offer on all the cranks and cams.. they took it. so here is the scoop . the 58mm crank has a 14 mm wrist pin, the 61.5 has a 15 mm pin,, i will start fresh with PM'S so far no pistons .. i have 2 52mm pistons that fit the 14 mm wrist pins it says 90cc big bore on the box.. so what is 90 stock mm?
  15. #30
    6,816
    Stock bore on a atc90 is 50mm and the stroke is 45.6mm .
    Congrats on the score .
