Results 1 to 13 of 13
Thread: backfire, 250R
    Benson, NC
    34
    backfire, 250R
    One of my 85 250R's has started to backfire on occasion when kicking it. Last couple of times I have had it out It would do this mid kick and really really hurt the bottom of my foot. One time it came around and hit my chin .. massive pain .. Now I'm scared to kick it. am I doing something wrong or does my trike have some issues?
    juggaloclownz18's Avatar
    juggaloclownz18 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    The woods of 315 - NY
    303
    a couple of weeks ago my buddy had this problem with his blaster and it would not start, it would just backfire mid kick..... ended up being he sheared his woodruff key, i dont know if this could be your prob. or not but might be something to look into, but you might want to wait until someone else chimes in because im just guessing....
    85 ATC250r (been waiting way too long!!)
    Tusk Hand Guards
    DG full exhaust (want different one)
    TAG handlebars
    +4 LSR axcaliber axle, carrier, hubs
    FMF Carbon Fiber reeds,
    K&N Filter/air box lid removed
    Motion Pro Twist Throttle
    Pro Armor Tether switch
    Seal Savers - long version
    23" Dirt Devil front - 22" holeshots back
    Soon to be ported/polished (got the work setup on trade)
    Sep 2005
    MICHIGAN
    2,027
    most likely it is building up unburnt gas then a spark sets off the explosion. Poor timing or weak stator can cause that (exhaust backfire)
    I think lean or preignition or over advanced timing does it too and is a carb side backfire
    86 T3
    84 T3
    86 KX250
    Oct 2009
    lindenwold new jersey
    890
    Watch your reeds, I use to blowout stock reeds all the time when she backfired on the start(unspent fuel in carb). If she don't start up after the BF check the plug and if it not that it's the reeds. As for kneeing yourself in the chin,,,well that does happen now and then and a good way to know you have compression. A few weeks ago I was at a race and stalled on the gate. I ate my knee and the quad riders got a laugh
    Sep 2005
    MICHIGAN
    2,027
    oh bad reeds, forgot about that. I totally agree
    86 T3
    84 T3
    86 KX250
    Southern MN
    1,875
    I agree with juggaloclownz18 above ^ Sheared flywheel key. I have had the problem numerous times on 2 stroke dirtbikes/ 3 wheeers. Pull the flywheel, and check out the key that holds it on the end of the crank shaft.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Richland WA
    808
    Quote Originally Posted by Yamaha_Rules69 View Post
    Only two possibilities:
    1.) sheared key, but it probably wouldnt run at all then, depending on where the rotor stopped at. A sheared key probably lets the rotor spin.
    2.) bad wiring in the ignition system. The CDi stores charge but wont fire it until it gets a signal from the pulse generator. A loose terminal on the PG or some other flaky connection on the CDI. Thats the only thing that can cause early fire. The only other way is to have an extremely hot ignition system, which it probably doesnt have.
    Benson, NC
    34
    Thanks for all the replies. I totally forgot about posting this. I may take a look at the reeds and flywheel tomorrow. it is a bit on the rich side too, I bet that the potential for backfire would only be made worse by that, if the reed is broken.
    testing ..
    Oct 2007
    macgregor ,Manitoba
    99
    I'm having the same problem with my 86 250r,it did run for a bit but now i can't start it.And when it does it only runs a few seconds.I have a Boyesen reed block system.Should that make a difference on my carb settings?Srry for asking this in your thread,just frustrated.Oil seems to be really dirty too from just a ride around the block.This is the first time out since the rebuild.Anyone have any ideas other then whats mentioned here?
    Masshole
    2,191
    Pull the flywheel, sounds like a sheered key, although i have no input on dirty oil. Is it just dirty or filled with alum? Slipping clutch discs can make some cruddy oil.
    Oregon
    2,471
    Exhaust leak will cause a backfire, check the woodruff key, check your reeds.
    Make SURE your the head pipe is fully seated and sealed on the flange!
    Keep us posted
    If you have Bought a item from me, Please leave me feedback
    If your buying a item from me check my feedback
    Click on link ~ http://www.3wheelerworld.com/showthr...ceaserthethird
    Oct 2007
    macgregor ,Manitoba
    99
    thx guys ,will try in 2 weeks when i get home.
    Oct 2007
    macgregor ,Manitoba
    99
    i tryed everything u guys suggested.The trike still doesn't wanna run.It wants to start but doesn't.Has lots of spark.reeds have been changed to stock.Spark plug is soaked every tome.carb was clogged at main fuel line.Seems to me a fuel prob,any suggestions?
