Thread: Honda 250 es / trx / sx etc carb choke plunger questions
    Worcester, MA
    1,117
    I need a carb choke plunger to replace the one that seems to be fused to my carb walls, going to have to drill it out.
    16046-HA0-013 is the part number
    Found this on eBay
    http://cgi.ebay.com/ebaymotors/HONDA...Q5fAccessories
    Says it fits all years of the SX and ES, but I've heard the 85 models have a smaller diameter plunger and the 86/87 models would NOT interchange.
    Which is true? Also, does the TRX300 utility quad have the same carb? Thanks
    YES, I found the Keihin maybe model08 versus 03 different diameters. Those may not be the actual numbers but they are certainly different plunger diameters. Probably all Honda's attempt on the 85 250SX cold start issue...... One may be an 05 Keihin but I know that the good starting carb is the Keihin 08...............
    I'm sorry I forget the actual numbers........
    a 350X carbs wth SX jets, the A?B lid off and an exhaust help her giddy-up and go
    Don't be scared to propane torch that puppy, the aluminum won't melt at that temp.......
    Worcester, MA
    1,117
    Will try a small propane torch, no penetrating fluid and force would budge it. By the way, would you be interested in doing the welding work to extend my BR driveshaft and swingarm 3", maybe the fork extension weld and rear shock mount once I get it figured out? Figured you were in/near Massachusetts anyway and had access to machines.
    ^ Yes sir I will do it in the lathe so it is true..... Will PM address
    Drive it over, stuff it in a wheelbarrow or ship it over, piece of cake!! (with cookie crumbles of course)
