Results 1 to 7 of 7
Thread: tri-z sprocket and brake hubs
    australia
    34
    has anyone tryed using other types of sprocket hubs, as my steel insert in the ally hub is flogged out, also other brake hubs
    na
    5,702
    91 and up Banshee sprocket hubs are a direct fit.
    There are no brake hubs that I am aware that fit, but you can use 04 YFZ 450 rear quad rotors, on the front and rear of the Z.
    You will have to space your rear caliper over about .250" with spacers to fit the YFZ rotor. The front will bolt right on.
    You may also need to open the mount holes up on the YFZ rotors a few millimeters to bolt to the Z hubs..It varies.But it is all minimal modding.
    Proudly NOT a member of
    "Team on the Teat"
    australia
    34
    thanks im on the hunt, so does the axle for a banshee change over as well, as i found a complete axle, wheel hubs, and sprocket hub
    na
    5,702
    Yep it all fits except the carriers, and rear rotor, and rotor hub, are different.
    The axle and hubs will work, but the banshee used larger bolt hubs so they wont fit OEM Z wheels.
    "Team on the Teat"
    australia
    34
    cheers mate
    i have raptor 660 wheel hubs on now also a while ago i got a atc 250r seat done buy mrs mosh top work please pass on my thanks
    heres what i got and check out the chicken wing shirt
    na
    5,702
    No problem Man..
    Nice Z!
    I will pass your thanks on to the Mrs...
    "Team on the Teat"
    Aug 2005
    Lockport, NY
    2,395
    I have a NOS banshee sprocket hub that I would sell for $80 USD plus international shipping.
