Thread: Colorado 250R riders-jetting baseline?
    CO
    64
    I just got my '86 250R motor mounted, and all the accessories bolted on. It is a stock motor, running a Keihin PJ from an '88 TRX250R, open pod filter with foam outer. I purchased the carb from someone at about 500ft elevation (near 4,500 here), so it is running mosquito-fogger rich (even w/ the airfilter off), and won't idle.
    Do any of you CO riders have an idea of where I should start as a baseline for jetting?
    Also, where is a good place to get jets or a jetting kit?
    Thanks!
    Full Suspension Kart powered by '86 250r in progress
    Quote Originally Posted by 3wheelmecca View Post
    Dang! I'm fat and i've never seen that. And I ride my R like a truckstop ho.
    Blossvale NY
    4,563
    while im not from CO, i can tell you that at higher elevation, the air is thinner, which in turn requires leaner jetting. just drop your main jet 1 size at a time till you get the main circuit dialed in. after you get that main dialed in, you can address the mid range (1/4-3/4 throttle) with the needle clip setting, and then you may find you need to lean the pilot a step. jetting over the internet is tricky at best. just focus on one fuel circuit at a time so you dont wind up chasing your tail not knowing what adjustment had what effect. and the nice thing about your position is that you are starting at a rich condition, making it relatively easy to incrementally work your way leaner till you get good performance without putting your engine in danger...
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    CO
    64
    No other input???
    CO
    64
    So I guess I'll try one last time? Can anyone give me a place to start so I don't have to buy like 70 jets and go from the bottom?
    COLORADO
    685
    wait for it........
    I am starting working at Ray's manana, I will get you the setting for this elevation.
    I will email you holmes.
    You will cry, you will scream if you've heard half the **** I've seen.
    Are you gonna get up and burn an X in your head?
    "Cut throught the bone and cut through the wire"
    Trikes:
    84&85 Tecates
    85 R
    85 X
    Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
