Results 1 to 15 of 18
Thread: Wheels spacers that piss me off....
    Oct 2007
    Minneapolis mn
    4,067
    So I put a pair of these wheels spacers on the back of my BR (1.5") and liked them up until yesterday when I had a little incident out on the trail. Seems as though the studs on the spacers (bolts) decided not to stay tight, and lost a wheel off the back of my BR way the heck back in the woods... Managed to get the spacer off and rob enough lug nuts and nylocks to keep the rear wheels on, and got it limped out of the sticks and back to the trailer, but talk about a butt puckering experience to have a rear wheel pop off at 25 mph! Amazingly I didnt wreck anything.
    Question being, red lock-tite and external star washers and a butt load of torque on the studs (bolts)??? Think they would hang together enough to go riding again? I am certainly bringing a ratchet and socket along to be able to check them mid ride!
    scottp597's Avatar
    scottp597 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2009
    Lowell, IN
    153
    Wow talk about a bad day at least you didn't fall off the machine at a faster speed or anything! I would think red loctite and some elbow grease would be fine
    juggaloclownz18's Avatar
    juggaloclownz18 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    The woods of 315 - NY
    303
    Dont they make locking lugs for motorcycles? If so i would imagine there would be a bike out there with the same size lugs as our machines.... Just thinking out loud LOL
    Either way, thats not good at all, i would hate to have that happen to me.... (note to self: Go tighten mine on the double)
    Sorry to hear about it though
    Last edited by juggaloclownz18; 06-24-2010 at 03:18 PM. Reason: zombie headed today
    85 ATC250r (been waiting way too long!!)
    Tusk Hand Guards
    DG full exhaust (want different one)
    TAG handlebars
    +4 LSR axcaliber axle, carrier, hubs
    FMF Carbon Fiber reeds,
    K&N Filter/air box lid removed
    Motion Pro Twist Throttle
    Pro Armor Tether switch
    Seal Savers - long version
    23" Dirt Devil front - 22" holeshots back
    Soon to be ported/polished (got the work setup on trade)
    Oct 2007
    Minneapolis mn
    4,067
    Quote Originally Posted by scottp597 View Post
    Wait a second... Who said I fell off? jk.. I rode it to the ground! It was really weird, because it didnt ever wobble on the back end. The studs backed into the spacers, and I never felt the nuts getting loose on the wheels. The holes arent tore up, or oblonged at all...
    Central NY
    121
    If you put on some loc tite and use lock washers/stars you should have no problem at all. However i agree i would have a socket and be checking for awhile till i was comfrotable again with them. That had to be pretty scary surprised there was no warning at all. Most people would have crashed on that one, experience wins again..
    Own 86 250sx
    85 350x
    sold 86 250sx
    110, 185s, 200s, 250es
    Project 85 250r
    If everyone else is looking down at you, Get a ladder..
    Baltimore, MD
    6,088
    Blue loctite, not red. Make sure threads are clean. Let cure overnight. You should be fine.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Oct 2007
    Minneapolis mn
    4,067
    Veal-- Why blue over red?
    Manitoba
    536
    Now are you saying 1) you originally did use loctite and lock washers and it came loose or 2) This is your proposed solution?
    If that doesn't work, I would throw them in the garbage. Something's not up to the strain.
    Blue loctite is for non-permanent installs. The studs going into the spacers, I would think red loctite would be fine as you wouldn't be removing them.
    84 200x
    Oct 2007
    Minneapolis mn
    4,067
    Too late they are now red loctited...(want them to be permanant) That is/was my purposed fix... If they come apart again, Just like the Grizz said... They will be garbage bound!
    84atc200's Avatar
    84atc200 is offline At The Back Of The Pack Arm chair racerFirst time rider
    new cumberland
    216
    i just put back-up nuts on mine.
    Oct 2007
    Minneapolis mn
    4,067
    Back up nuts?
    84atc200's Avatar
    new cumberland
    216
    Yea each bolt has 2 nuts on it instead of 1 nut.
    Oct 2007
    Minneapolis mn
    4,067
    Gotcha... I have ITP wheels so I have to run a acorn style lug nut... Not much of an option here...
    jadleybray's Avatar
    jadleybray is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2007
    oregon
    352
    Loctite works by compression, no need to cure
    Manitoba
    536
    Just an added thought here, if you weren't previously, use a torque wrench to ensure you tighten them adequately.
    84 200x
